Hello all,
I've authored a Blu-Ray which is refused by Eclipse in the replication plant. Their diagnostic tool says my total bitrate exceeds 56 Mb/s (48 Mb/s is the max.). However after checking all my bitrates, I'm much lower and inside what the standard allows. Please check the different captures and report from BDinfo and Eclipse.
Any help appreciated.
Eclispe error:
H264 bitrate analyze by BDinfo:
Global report by BDinfo:
Disc Label: BD
Disc Size: 23,165,613,392 bytes
Protection: AACS
BDInfo: 0.7.5.5
Notes:
BDINFO HOME:
Cinema Squid (old)
http://www.cinemasquid.com/blu-ray/tools/bdinfo
UniqProject GitHub (new)
https://github.com/UniqProject/BDInfo
INCLUDES FORUMS REPORT FOR:
AVS Forum Blu-ray Audio and Video Specifications Thread
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
PLAYLIST: 00001.MPLS
<--- BEGIN FORUMS PASTE --->
Code:Total Video Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track ----- ------ ------- -------------- -------------- ------- ------- ------------------ --------------------- 00001.MPLS AVC 1:52:02 23,154,438,144 23,165,613,392 27.56 20.00 LPCM 2.0 2304Kbps (48kHz/24-bit) DTS-HD Master 5.1 3748Kbps (48kHz/24-bit)Code:DISC INFO: Disc Label: BD Disc Size: 23,165,613,392 bytes Protection: AACS BDInfo: 0.7.5.5 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:52:02.215 (h:m:s.ms) Size: 23,154,438,144 bytes Total Bitrate: 27.56 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 19998 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio French 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit DTS-HD Master Audio French 3748 kbps 5.1 / 48 kHz / 3748 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00001.M2TS 0:00:00.000 1:52:02.215 23,154,438,144 27,556 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:09:40.912 20,691 kbps 36,317 kbps 00:00:27.485 29,085 kbps 00:00:23.440 27,238 kbps 00:00:23.565 107,865 bytes 749,301 bytes 00:00:14.681 2 0:09:40.912 0:23:56.767 19,201 kbps 29,712 kbps 00:24:05.652 27,077 kbps 00:24:03.441 25,221 kbps 00:26:47.272 100,108 bytes 831,411 bytes 00:12:38.257 3 0:33:37.680 0:11:27.228 19,906 kbps 39,610 kbps 00:44:59.321 29,392 kbps 00:44:58.320 24,411 kbps 00:38:19.714 103,783 bytes 715,556 bytes 00:44:50.187 4 0:45:04.908 0:09:22.603 19,712 kbps 32,801 kbps 00:53:10.103 28,784 kbps 00:53:07.893 26,473 kbps 00:53:03.263 102,768 bytes 676,748 bytes 00:52:36.027 5 0:54:27.511 0:14:58.271 20,520 kbps 32,933 kbps 01:00:36.299 29,337 kbps 01:00:36.299 25,997 kbps 01:06:26.982 106,979 bytes 735,976 bytes 00:57:23.773 6 1:09:25.782 0:06:28.971 19,803 kbps 34,108 kbps 01:14:28.380 28,974 kbps 01:12:34.016 26,133 kbps 01:12:30.846 103,241 bytes 731,807 bytes 01:12:32.598 7 1:15:54.754 0:16:35.786 19,716 kbps 32,225 kbps 01:32:27.458 27,634 kbps 01:26:41.863 24,777 kbps 01:26:36.858 102,792 bytes 825,917 bytes 01:17:01.450 8 1:32:30.540 0:06:47.781 20,592 kbps 37,354 kbps 01:36:07.303 29,499 kbps 01:35:34.436 27,253 kbps 01:35:34.812 107,359 bytes 675,652 bytes 01:39:13.906 9 1:39:18.322 0:12:43.893 20,797 kbps 38,068 kbps 01:49:15.131 29,340 kbps 01:49:04.162 27,185 kbps 01:49:14.214 108,433 bytes 866,763 bytes 01:42:33.564 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00001.M2TS 4113 (0x1011) 0x1B AVC 6722.132 19,998 16,803,717,610 91,418,640 00001.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 6722.132 2,310 1,941,375,768 10,755,545 00001.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 6722.132 3,748 3,148,991,980 18,162,091QUICK SUMMARY:
Disc Label: BD
Protection: AACS
Playlist: 00001.MPLS
Length: 1:52:02.215
Video: MPEG-4 AVC Video / 19998 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: French / LPCM Audio / 2.0 / 48 kHz / 2304 kbps / 24-bit
Audio: French / DTS-HD Master Audio / 5.1 / 48 kHz / 3748 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
While it is not out of the realm of possibility for your freeware consumer app to be more accurate than the industry standard verification app (though that sounds awkward even saying that), it ultimately doesn't matter what BDInfo says, as you can't get your BD pressed without it first passing verification.
However, I do note that while bdinfo gives you max down to the level of 1 second, it doesn't get more granular. It could very well be that you have an instantaneous (1 frame) max that exceeds the limit, but frames around it when averaged to the second show a much lower average. In other words, you have a SPIKE.
Which encoder and/or muxer did you use? Were you using true 2pass vbr with integrated BD vbv constraints, or were you using something like 1 pass, crf, etc? That could easily account for the difference.
Regardless, you will have to re-encode. I suggest you do only the segment in question (unless you truly didn't use proper 2pass, in which case it would be better to redo the whole thing properly).
[Spoken from someone who has had to deal with mastering verification before.]
Scott -
Thank you.
In the meantime, I’ve just found the solution. Actually, after compiling the Blu-Ray in DVD-architect, I remux an audio track with a DTS HD Master Audio 5.1 stream using MultiAVCHD/TSMuxer (cause DVD-Architect only supports the old Dolby Digital 5.1). I’ve read on Doom9 forum that TSmuxer is always refused by Eclipse.
No more bitrate alert anymore. There was no peak above 48 Mbit/s. It was just a muxing problem. -
3 things:
I did ask you what muxer you were using, because, as you found out, it does bear on the issue.
I could have told you that muxman wasn't compliant enough. It was reverse engineered, and while its dvd capabilities and compatibilities are nearly complete, its bd portion has a way to go.
Monitor your bitrate still. Lossless audio streams such as TrueHD, DTS-MA, also have been known to spike their instantaneous bitrates, and what happens if the audio and the video spikes coincide? A better muxer can smooth that out somewhat, but not completely.
Scott -
It's fine via Eclipse?
Note: TSMuxer is better, but is still reverse-engineered AFAIK (unless the author went and bought the actual specs and didn't tell us, which I doubt). Use at your own risk. For burned discs, its not a big deal, but once you go factory-pressed discs, it is best to play by their rules.
Solar eclipse converting AVCHD to image sequences...
By jeff d in forum Video ConversionReplies: 7Last Post: 28th Aug 2017, 20:16 -
Downloading HDS stream gives forbidden error or auth token error
By vishiwig in forum Capturing and VCRReplies: 1Last Post: 10th Jun 2017, 16:45 -
Spectral Band Replication Filter in Adobe Audition, Audacity or other
By fbreve in forum AudioReplies: 19Last Post: 14th Jul 2016, 12:16 -
How to create a checksum file of DDP for replication facility?
By rosiestarr in forum Authoring (DVD)Replies: 5Last Post: 19th Oct 2015, 14:15 -
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 11:12
