  1. Hi there,
    I got the video source from here: https://4kmedia.org/sony-mont-blanc-hdr-uhd-4k-demo/
    On my Mac,
    The video plays fine on VLC with fruitful colours, but the colour is pale on Quicktime player or Safari.
    However LG's one doesn't have the same issue:
    https://4kmedia.org/lg-cymatic-jazz-hdr-hlg-uhd-4k-demo/
    In which I checked the Sony's mediainfo:
    General
    Complete name                            : Sony Mont Blanc HDR UHD 4K Demo.mp4
    Commercial name                          : HDR10
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp42/iso4)
    File size                                : 755 MiB
    Duration                                 : 1 min 28 s
    Overall bit rate                         : 72.0 Mb/s
    Encoded date                             : UTC 2017-01-27 06:42:55
    Tagged date                              : UTC 2017-01-27 06:42:55
    Video
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Format profile                           : Main 10@L5.1@High
    Codec ID                                 : hvc1
    Codec ID/Info                            : High Efficiency Video Coding
    Bit rate                                 : 71.8 Mb/s
    Width                                    : 3 840 pixels
    Height                                   : 2 160 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 50.000 FPS
    Chroma subsampling                       : 4:2:0 (Type 2)
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.173
    Stream size                              : 753 MiB (100%)
    Color range                              : Limited
    Color primaries                          : BT.2020
    Transfer characteristics                 : PQ
    Matrix coefficients                      : BT.2020 non-constant
    Mastering display color primaries        : R: x=1.000000 y=1.000000, G: x=1.000000 y=1.000000, B: x=1.000000 y=1.000000, White point: x=1.000000 y=1.000000
    Mastering display luminance              : min: 0.1000 cd/m2, max: 0 cd/m2
    Codec configuration box                  : hvcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Constant
    Bit rate                                 : 192 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 2.01 MiB (0%)
    Language                                 : English
    I noticed that the master display colour primaries are incorrect, so I wonder if it could be fixed.
    I have tried to transcode with correct values, e.g.
    Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312500 y=0.329000
    Mastering display luminance              : min: 0.0040 cd/m2, max: 1100 cd/m2
    but unfortunately it doesn't give a positive result.
    So does anyone know what kind of parameters do we need to pass to activate the HDR functionality for Safari/Quicktime Player?
    Thank you in advance!
    Aug 2006
    I don't have a Mac, Quicktime or Safari. I do use VLC on my Windows machine with a monitor that can switch between HDMI 1.4/SDR mode and HDMI 2.0/HDR10 mode.
    The Sony: Mont Blanc HDR demo uses HDR10 for its HDR metadata. I downloaded this demo some time ago, and the colors are rendered nicely using VLC, but any of the other video players that I have which don't support HDR10 render a washed-out picture.
    The newest version of VLC can use tone-mapping to simulate HDR on an SDR-only monitor. This version of VLC is also able to display natural-looking colors using the HDMI 2.0/HDR10 connection on my monitor, although they are not quite as vivid.
    According to its description at the website, the LG: Cymatic Jazz HDR/HLG demo uses Hybrid Log Gamma for its HDR metadata** instead of HDR10. I can't download it for testing because the website won't allow it due to high activity for the file.
    Are you certain that Quicktime and Safari support HDR10? Perhaps they only support HLG HDR.
    [Edit] ** Correction: HLG does not use metadata
    Aug 2006
    I was finally able to download the LG: Cymatic Jazz HDR/HLG demo. When playing it VLC rendered the video in SDR (using tone mapping to approximate BT 2020) for both HDMI 2.0 and HDMI 1.4.
    HDR support is simply not as good for software players, computers and monitors at this point as it is for TVs. My monitor supports HDR10 (but no other type of HDR) and the same is true for my Intel processor's iGPU.
  4. Originally Posted by usually_quiet View Post
    Oh! Thank you very much for your comment!
    You have solved the puzzles!
    So to conclude,
    - LG source is HLG HDR, which is why it can be rendered by Quicktime
    - VLC does tone mapping under the hood when HDR output is not supported
    I have verified by transcoding the LG's video with BT 709 colour space without tone-mapping,
    and it does show the same colour as it was in BT 2020.
    Great!
    Now leave with one question, as to the mediainfo LG is showing:
    mediainfo LG_Cymatic_Jazz_HDR10_4K_Demo.mp4
    General
    Complete name                            : LG_Cymatic_Jazz_HDR10_4K_Demo.mp4
    Codec ID                                 : isom (isom/iso2/mp41)
    File size                                : 1.11 GiB
    Duration                                 : 2 min 38 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 60.1 Mb/s
    Encoded date                             : UTC 2017-06-04 23:05:26
    Tagged date                              : UTC 2017-06-04 23:05:26
    Writing application                      : Lavf57.72.101
    Video
    Format                                   : HEVC
    Codec ID                                 : hev1
    Bit rate                                 : 60.0 Mb/s
    Frame rate mode                          : Variable
    Frame rate                               : 59.940 (60000/1001) FPS
    Minimum frame rate                       : 59.920 FPS
    Maximum frame rate                       : 59.960 FPS
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.121
    Stream size                              : 1.11 GiB (100%)
    Writing library                          : ATEME Titan KFE 3.7.3 (4.7.3.1003)
    Mastering display color primaries        : Display P3
    Audio
    Format                                   : AAC LC
    Bit rate mode                            : Variable
    Bit rate                                 : 126 kb/s
    Maximum bit rate                         : 128 kb/s
    Stream size                              : 2.38 MiB (0%)
    Default                                  : Yes
    Alternate group                          : 1
    The commercial name saying HDR10 and transfer saying PQ, but it is not HDR10 nor PQ isn't it?
    as far as I know,
    PQ & HLG are 2 different transfer function,
    and HDR10 specifies the use of SMPTE ST 2084 EOTF, which is for PQ instead of HLG.
    Is the metadata HDR10 & PQ not trust worthy?
    Or how should I identify the media is HLG?
    Thank you so much!!
    Aug 2006
    So to conclude,
    Great!
    General
    Video
    Format                                   : HEVC
    Codec ID                                 : hev1
    Bit depth                                : 10 bits
    Audio
    Format                                   : AAC LC
    Bit rate                                 : 126 kb/s
    Default                                  : Yes
    Alternate group                          : 1
    as far as I know,
    Thank you so much!!
    Maybe MediaInfo's author made a mistake or is still learning out how to interpret the HDR information in the video headers? Maybe the header is incorrect?
    I have MediaInfo MediaInfo 19.04, the latest version. Below is the MediaInfo report for the file that I downloaded yesterday from https://4kmedia.org/lg-cymatic-jazz-hdr-hlg-uhd-4k-demo/. I used the "Download" button on the webpage to obtain this file. I'm not sure why your download is an mp4 file using a Mac and mine is a ts using a Windows PC, but as you can see, the report does say "Transfer characteristics: HLG / BT.2020 (10-bit)"
    General
    Complete name                            : C:\Users\usually_quiet\Videos\LG Cymatic Jazz 4K Demo\LG Cymatic Jazz 4K Demo.ts
    Format                                   : MPEG-TS
    File size                                : 738 MiB
    Duration                                 : 4 min 57 s
    Overall bit rate                         : 20.8 Mb/s
    Video
    Menu ID                                  : 301 (0x12D)
    Format                                   : HEVC
    Format profile                           : Main 10@L5.1@Main
    Codec ID                                 : 36
    Duration                                 : 17 h 6 min
    Bit depth                                : 10 bits
    Writing library                          : ATEME Titan File 3.7.7 (4.7.7.1)
    Transfer characteristics                 : HLG / BT.2020 (10-bit)
    SEI_rbsp_stop_one_bit                    : Missing
    Audio
    Format                                   : AAC LC
    Format version                           : Version 4
    Muxing mode                              : ADTS
    Codec ID                                 : 15-2
    Delay relative to video                  : -36 ms
  6. Shocked.
    So there were 2 pages... (woosh)
    https://4kmedia.org/lg-cymatic-jazz-hdr10-uhd-4k-demo/
    Both of them state they are MP4 files but yours is in TS,
    and HDR10's one claims itself HDR10 but it isn't too (mind-blown)
    But anyway, yours should be the correct one, glad that you have it.
    So turn out the HDR10's one only got the HDR10 label (metadata) but the content itself were in SDR/HLG?
    Thank you very much for your time!
    Interesting to find out how decoder activates the HDR...
    Aug 2006
    Shocked.
    That certainly explains why the files we downloaded were so different.
    You linked to https://4kmedia.org/lg-cymatic-jazz-hdr-hlg-uhd-4k-demo/ in your first post in this thread, so that's where I went to download. I had no idea that the other page, https://4kmedia.org/lg-cymatic-jazz-hdr10-uhd-4k-demo/, existed until now.
    The fake HDR10 file certainly plays like it uses HLG for HDR and not like it uses HDR10 for HDR, but the information that MediaInfo and VLC report about the fake HDR10 file mention PQ. Could it actually be PQ HDR? (I know almost nothing about PQ.)
    My version of MediaInfo reports the following:
    General
    Complete name                            : C:\Users\usually_quiet\Videos\LG Cymatic Jazz HDR10 4K Demo.mp4
    Video
    Format                                   : HEVC
    HDR format                               : SMPTE ST 2086, HDR10 compatible
    Codec ID                                 : hev1
    Bit depth                                : 10 bits
    Audio
    Format                                   : AAC LC
    Bit rate                                 : 126 kb/s
    While playing the fake HDR10 file, VLC says "Color primaries: ITU-R BT.2020" and "Color transfer function: SMPTE ST2084" . SMPTE ST2084 is PQ.
  8. So at the end I guess the PQ's one even though has the PQ transfer function, however the colour primaries are in Display P3, which Mac is supported on their retina display.
    With the luminance of 48cdm I personally don't think this is in HDR. (I'm not expert in this field actually)
