I currently use VideoReDo TV Suite for Tivo and MPEG files, but there has to be an easier way.
Free is best, but willing to pay for a good solid program. Ideas?
Very simple... just editing out cuss words or scenes that are extremely violent, etc.
I'd like the ability to just "blank out" the audio in some scenes so there is no visual gap. -
Don't think you can do the audio easily in VideoRedDo without cutting your clip into pieces, some as small and a single word, reducing the audio on those, and recombining.
It's slightly easier with VideoReDo's main competitor TMPGencSmart Renderer because it has built-in multiplexing tools which VideoReDo seems to lack.
In that case you would first bring your file into an audio editor like Audacity.
Make your audio dips.
Output the new audio file.
Combine the new audio with the original video in the multiplexer tool.
Bring the newly combined file into the main program (or even bring it into VideoReDo )
Make your video cuts
Output again.
Obviously you can also use one of the free multiplexing tools available here for recombining your audio and video -- but I find the TMPGenc tools so solid and reliable I haven't used any of the others in years and someone else will have to recommend one.Last edited by smrpix; 8th May 2019 at 08:01.
Thanks!
Can anyone recommend some decent free multiplexing tools? -
You can use OpenShot Video Editor, load the video, split/cut/blank audio, export, free software and an all in one program, the easiest solution hands down.
here's a video guide showing several different ways on how to do it.
https://www.youtube.com/watch?v=BQS2tmgD_Rk
if you want to get "dirty" open the video in audacity directly and do the audio edition and then export to wav, using avidemux open the original file, disable the original audio track, load the edited audio track, do the video cutting and export it all
or you can use avisynth and do audio trim/blank video cuts but its way to slow and you would have to note down all the time codes ....Last edited by ricardouk; 10th May 2019 at 06:03.
I love it when a plan comes together!
Software/tool to detect music and dub over it or mute it? (music detection)
By tinydog in forum AudioReplies: 3Last Post: 17th Jan 2019, 08:19 -
Audio decreases a lot in some scenes
By hisaishi in forum Software PlayingReplies: 6Last Post: 8th Nov 2018, 06:01 -
Program to sync audio with scenes from video.
By lgblublu in forum AudioReplies: 2Last Post: 28th Dec 2016, 08:20 -
Audio and scenes
By Chintaru in forum AudioReplies: 5Last Post: 27th Feb 2016, 05:17 -
Software to edit/cut/merge/convert MKV audio and video @ original bitrates
By Yanta in forum Video ConversionReplies: 9Last Post: 19th Oct 2014, 15:11
