I'm downmixing a DTS-MA file to a FLAC file and no matter what settings I use it keeps changing the bit depth of the output file from 24-bits to 16-bits. I'd like for it to remain 24-bits. Here's the log information:
eac3to v3.34
command line: "C:\Users\User\Downloads\Software\Miscellaneous\In stallers\eAC3to\eac3to334-UsEac3to129\eac3to.exe" "C:\Users\User\Videos\Projects\MKV Tools\Output\01 - James Bond - Title Sequences\20 - Tomorrow Never Dies\03 - Audio\01 - Original\01 - DTS\20 - Tomorrow Never Dies - Title Sequence (04).dts" "C:\Users\User\Music\Projects\eAC3to\20 - Tomorrow Never Dies - Title Sequence (04).dts_.flac" -progressnumbers -log="C:\Users\User\Downloads\Software\Miscellaneou s\Installers\eAC3to\eac3to334-UsEac3to129\UsEac3To.log"
DTS Master Audio, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
Decoding with libDcaDec DTS Decoder...
libDcaDec reported the warning "XLL output not lossless". <WARNING>
Encoding FLAC with libFlac...
Creating file "C:\Users\User\Music\Projects\eAC3to\20 - Tomorrow Never Dies - Title Sequence (04).dts_.flac"...
The original audio track has a constant bit depth of 16 bits.
Superfluous zero bytes detected, will be stripped in 2nd pass.
Starting 2nd pass...
Decoding FLAC...
Reducing depth from 24 to 16 bits...
The processed audio track has a constant bit depth of 16 bits.
eac3to processing took 27 seconds.
Done.
Results 1 to 12 of 12
Why would you want to convert 16 bits to 24 bits?The original audio track has a constant bit depth of 16 bits.
I don't. Look at the log file. It says:
"DTS Master Audio, 5.1 channels, 24 bits, 48kHz" and "Reducing depth from 24 to 16 bits..."
I'm not converting from 16 bits to 24 bits. If it is 16 bits, then can you can tell me why it's saying it's 24 bits, then 16 bits, then 24 bits again? -
something is not identifying the original correctly it looks like.
48khz is normally 16 bit as outputted.The original audio track has a constant bit depth of 16 bits.
Superfluous zero bytes detected, will be stripped in 2nd pass.--
The file is encoded at 24 bits. But 8 of the bits are zeroes. I.e. the file looks something like this:
Since the lower bits are ALL zeroes FOR THE WHOLE FILE it is actually 16 bits. eac3to can't detect it upfront, only after scanning the complete file in the first pass.Code:10101111001101110101101100000000
Well, you did rip this right from the Blu-Ray, didn't you? So it's like this on it.
Why they did this I don't know. My guesses it's one/some/all of:
1. authoring house didn't know any better
2. authoring house missed this detail
3. authoring house/studio wanted better numbers for better advertising (MORE = BETTER, RIGHT? 2048 bits, 1 Billion THz etc. ) -
There is no free or cheap DTS-HD MA encoder so no one accidentally (re-)encodes DTS-HD MA at home. It must have been like this on the original Blu-Ray to begin with.
Batch downmixing audio to stereo while just copying video stream?
By bizzybody in forum Video ConversionReplies: 5Last Post: 30th Jan 2019, 03:33 -
EAC3To Incorrect Slowdown? EAC3To Broke?
By TheLastOfThem in forum AudioReplies: 44Last Post: 13th Jul 2017, 20:42 -
Downmixing AAC 6 channel to stereo with dialogue audio gain?
By vonsworld in forum AudioReplies: 4Last Post: 6th Dec 2016, 02:27 -
Possible incorrect audio downmixing (MPC-HC)
By asw3 in forum Software PlayingReplies: 3Last Post: 14th Feb 2016, 03:27 -
Surround channel downmixing to stereo in movie rips - why?
By smokeluvr1971 in forum AudioReplies: 5Last Post: 14th May 2014, 18:30
