With the GUI if you open any file it generates the .meta file and you can save it as a file and pass on for the batch scripts, etc.
It looks something like this
How do you skip the GUI part (don't use it) and generate the file with the command line version of TSMuxer?Code:MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --cut-start=10000ms --vbv-len=500 V_MPEG4/ISO/AVC, "C:\file.m2ts", insertSEI, contSPS, track=4113 A_DTS, "C:\file.m2ts", track=4352, lang=eng S_HDMV/PGS, "C:\file.m2ts", fps=23.976, track=4608, lang=eng
All I found is that you have to manually set the .meta file by setting up each line for each stream, which makes no sense because you get this auto-generated for you with the GUI, but can't with command line?
You can use echo and redirecting sign(s) to create script and later you can use command 'call' to run this script from batch.
Check this site - it is one of the best if not the best site dedicated to dos scripting.
https://www.robvanderwoude.com/redirection.php
Bellow example of script i use to create help file for ffmpeg, it should give you impression how to create script from script.
Code:@echo off @echo --------------- > ff_help_full.txt @echo ffmpeg version >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -version >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -buildconf >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -buildconf >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -pix_fmts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -pix_fmts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -sample_fmts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -sample_fmts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -filters >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -filters >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -formats >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -formats >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -codecs >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -codecs >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -decoders >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -decoders >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -encoders >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -encoders >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -bsfs >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -bsfs >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -devices >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -devices >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -sources device >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -sources device >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -sinks device >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -sinks device >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -hwaccels >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -hwaccels >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -protocols >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -protocols >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -layouts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -layouts >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg full help >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -h full >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo ffmpeg -colors >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @ffmpeg.exe -hide_banner -colors >> ff_help_full.txt @echo --------------- >> ff_help_full.txt @echo * EOH * >> ff_help_full.txt @timeout 30
You need to do something like:
Code:@echo "V_MPEG4/ISO/AVC, "C:\file.m2ts", insertSEI, contSPS, track=4113" >yourscript.meta @call tsmuxer.exe yourscript.meta outfilename
Code:Examples: tsMuxeR <media file name> tsMuxeR <meta file name> <out file/dir name> tsMuxeR can be run in track detection mode or muxing mode. If run tsMuxeR with only one argument then tsMuxeR display input track information required to construct meta file. If run tsMuxeR with two arguments tsMuxeR start muxing or demuxing process. Meta file format: File MUST has extension .meta. This file define files you want to multiplex. First line of meta file contain additional parameters that apply to all tracks. In this case the line should begin with the word MUXOPT. Following lines indicate a list of tracks and their parameters. The format is as follows: <code name>, <file name>, <parameters> Parameters are comma separated. Each parameter indicates the name and value. Example of META file: MUXOPT --blu-ray V_MPEG4/ISO/AVC, D:/media/test/stream.h264, fps=25 A_AC3, D:/media/test/stream.ac3, timeshift=-10000ms In this example one AC3 audio stream and one H264 video stream are multiplexed to BD disk. Input file name can reference to elementary stream or track inside container. Supported input containers: - TS/M2TS/MTS - EVO/VOB/MPG/MPEG - MKV - MOV/MP4 - MPLS (Blu-ray media play list file) Names of codecs in the meta file: - V_MPEGH/ISO/HEVC H.265/HEVC - V_MPEG4/ISO/AVC H.264/AVC - V_MPEG4/ISO/MVC H.264/MVC - V_MS/VFW/WVC1 VC1 - V_MPEG-2 MPEG2 - A_AC3 AC3/AC3+/TRUE-HD - A_AAC AAC - A_DTS DTS/DTS-Express/DTS-HD - A_MP3 MPEG audio layer 1/2/3 - A_LPCM raw pcm data or PCM WAV file - S_HDMV/PGS Presentation graphic stream (BD subtitle format) - S_TEXT/UTF8 SRT subtitle format. Encoding MUST be UTF-8/UTF-16/UTF-32 Each track may has addition parameters. Track parameters do not have dash. If parameter value has several words, parameter must be enclosed in quotes. Common additional parameters for any type of track: - track track number if input file is container. - lang track language. MUST contains exact 3 letters. Additional parameters for audio tracks: - timeshift Shift audio track to future (positive value) or to past. Measured at milliseconds. - down-to-dts Available only for DTS-HD tracks. Filter out HD part. - down-to-ac3 Available only for TRUE-HD tracks. Filter out HD part. - secondary Mux as secondary audio. Available for DD+ and DTS-Express. Additional parameters for video tracks: - fps Video fps. If not defined, default value auto detected from a source stream if present. If not, default value 23.976. - delPulldown Remove pulldown from the track if exists. This option lead to fps change from 30 to 24 if pulldown exists. - ar Override video aspect ratio. 16:9, 4:3 e.t.c. Additional parameters for H.264 video tracks: - level Overwrite level in the H264 stream. Note: option update headers only. The H264 stream may not meet the requirements of a lower level. - insertSEI If original stream does not contain SEI picture timing, SEI buffering period or VUI parameters, then add this data to the stream. This option is recommended for BD muxing. - forceSEI Add SEI picture timing, buffering period and VUI parameters to the stream. Rebuild data If data already exist. - contSPS If original video doesn't contain repetitive SPS/PPS then SPS/PPS will be added to the stream before each key frame. This option is recommended for BD muxing. - subTrack Used for combined AVC/MVC tracks only. TsMuxeR always demultiplex such tracks to separate AVC and MVC streams. This parameter defined reference to AVC part(if value=1) or or to MVC part (if value=2). - secondary Mux as secondary video (PIP). - pipCorner Corner for PIP video. Allowed values: "TopLeft","TopRight", "BottomRight", "BottomLeft". - pipHOffset PIP window horizontal offset from the corner in pixels. - pipVOffset PIP window vertical offset from the corner in pixels. - pipScale PIP window scale factor. Allowed values: "1", "1/2", "1/4", "1.5", "fullScreen". - pipLumma Allow PIP window to be transparent. Transparent colors are lumma colors in range [0..pipLumma]. Additional parameters for PG and SRT tracks: - video-width The width of the video in pixels. - video-height The height of the video in pixels. - fps Video fps. Recommended to define this parameter for more carefully timing processing. - 3d-plane Parameter defines number of the '3D offset track' which placed inside MVC track. Each message has individual 3D offset. This information stored inside 3D offset track. Additional parameters for SRT tracks: - font-name Font name to render. - font-color Font color. Color can be defined in hexadecimal or decimal format. If color 24 bit long (for instance 0xFF00FF) it's define RGB components. IF color 32 bit long (for instance 0x80FF00FF) it's define ARGB components. - font-size Font size in pixels. - font-italic Italic display text. - font-bold Bold display text. - font-underline Underlined text. - font-strikeout Strikethrough text. - bottom-offset Distance from the lower edge while displaying text. - font-border Outline width. - fadein-time Time in ms for smooth subtitle appearance. - fadeout-time Time in ms for smooth subtitle disappearance. - line-spacing Interval between lines. Default value 1.0. tsMuxeR supports addition tag inside SRT track. The syntax and parameters coincide with HTML: <b>, <i>, <u>, <strike>, <font>. Default relative font size (used in these tags) - 3. For example: <b><font size=5 color="deepskyblue" name="Arial"><u>Test</u> <font size= 4 color="#806040">colored</font>text</font> </b> Global addition parameters placed in the first line of the META file (MUXOPT). All parameters in this group started with two dashes: --pcr-on-video-pid Do not allocate separate PID for PCR, use an existing video PID. --new-audio-pes Use bytes 0xfd instead of 0xbd for AC3, True-HD, DTS and DTS-HD. Parameter is auto activated for BD muxing. --vbr Use variable bitrate. --minbitrate Sets the lower limit of the vbr bitrate. If the stream has a smaller bitrate then NULL packets will be inserted to hold the limit. --maxbitrate The upper limit of the vbr bitrate. --cbr Muxing mode with a fixed bitrate. Options --vbr and --cbr should not be used together. --vbv-len The length of the virtual buffer in milliseconds. The default value is 500. Typically, this option is used in together with --cbr. The parameter is similar to the value of vbv-buffer-size in the x264 coder, but defined in milliseconds instead of kbit. --no-asyncio Do not create a separate thread for writing. Also, this option disable flag FILE_FLAG_NO_BUFFERING for writing. Deprecated option. --auto-chapters Number. Insert a chapter every <nn> minutes. Used only for BD/AVCHD mode. --custom-chapters A semicolon delimited list of string in format hh:mm:ss.zzz --demux In this mode selected audio and video tracks are stored as separate files instead of muxing. utput name must be folder name. All selected effects (such as change of level for h264) are processed. When demux, certain types of tracks always get changed on storing into a file: - Subtitles in a Presentation Graphic Stream are converted into sup format. - PCM audio are saved as WAV files. --blu-ray Mux to BD diks. If output file name is folder, bluray disk is created as folder on HDD. For BD3D disks ssif files are not created at this case. If output file name has .iso extension, then BD disk is created as image file. --avchd Mux to AVCHD disk. --cut-start Trim the beginning of the file. Value should be completed with "ms" (the number of milliseconds), "s" (seconds) or "min" (minutes). --cut-end Trim the end of the file. Value should be completed with "ms" (the number of milliseconds), "s" (seconds) or "min" (minutes). --split-duration Split output to several files.The time specified in seconds --split-size Split output to several files. Values should be written using one of the following postfix: Kb,kib, mb,mib, gb,gib. --right-eye Use base video stream for right eye. Used for 3DBD only. --start-time Timestamp of the first video frame. May be defined as 45Khz clock (just a number) or as time in format hh:mm:ss.zzz --mplsOffset The number of the first MPLS file. Used for BD disk mode. --m2tsOffset The number of the first M2TS file. Used for BD disk mode. --insertBlankPL Add extra short playlist. Used for cropped video muxed to BD disk. --blankOffset Blank playlist number. --label Disk label for muxing to ISO file. --extra-iso-space Allocate extra space in 64K units for ISO disk metadata (file and directory names). Normally, tsMuxeR allocate this space automatically. But if split condition generates a lot of small files, extra ISO space may be required to define.
So like I wrote, you're stuck doing the .meta part manually. You load up the .m2ts in the GUI and it auto-generates the:
Code:V_MPEG4/ISO/AVC, "C:\file.m2ts", insertSEI, contSPS, track=4113 A_DTS, "C:\file.m2ts", track=4352, lang=eng S_HDMV/PGS, "C:\file.m2ts", fps=23.976, track=4608, lang=eng
Read help to tsMuxer - obviously you can analyse file with tsMuxer and based on this generate meta file - GUI has embedded parser for analysed data and editor to create meta file. If you do not wish to use GUI you need to substitute some functionality in different way.
So your proper question is: how to analyse file source with tsMuxeR.exe and based on this create meta file.
As i don't have m2ts file then i analysed different source and seem all important information is present.
So next question is how to select fields and values and create meta file - as i wrote previously SED or GREP (if present) or some similar tool is required.
mkvmerge command line
By barbosa in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2019, 07:09 -
vidCoder command line?
By Cazz in forum Video ConversionReplies: 0Last Post: 13th Nov 2018, 16:38 -
how can i generate old tv noise or off line effect?
By rama in forum EditingReplies: 8Last Post: 3rd Jan 2018, 09:35 -
tsMuxeR command line
By t00 in forum Blu-ray RippingReplies: 7Last Post: 19th Nov 2017, 12:20 -
command line util that returns video file info?
By wallywalters in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2017, 20:57
