I have seen mkv files 50% or even more compression from BD original, while there is not significant quality loss from original BD quality.
How to achieve best results of BD to smaller mkv conversion, when maintaining 1080 resolution?
What is best software for this?
Closed Thread
"Beauty is in the eye of the beholder". But I would say, so are compression artifacts.
Given the same efficiency codec, and similar settings, there is no possibility of a 50% drop in bitrate without an accompanyingly large drop in quality. BUT, depending on the choices in the settings and the type of content and the sensitivities and tastes of the watcher, some kinds of artifacts might be not noticeable or not significantly detrimental. My guess is that YOU may not notice (or care about) the difference much, but others might be more critical, myself included.
Regardless, in a more general and objective sense, the only way to get a BD down 50% in bitrate without much difference in quality (but make no bones, there will ALWAYS be some difference/loss) is to use a much more efficient codec & settings. BD usually uses AVC/h264. An HEVC/h265 re-encode could likely achieve a 50% reduction, and might even use settings more smartly to pass as nearly identical to the BD source.
Just don't be fooled into thinking you can get something for nothing.
Note, mkv or not mkv has nothing to do with it. That is just a container.
Encode with vidcoder and set the video encoding to 16 constant quality.
roberta-please do not open 2 threads about the same subject,this thread is closed.Continue in your previous thread.
https://forum.videohelp.com/threads/393048-How-to-shrink-40GB-BD-to-much-smaller-mkv-w...l-quality-lossI think,therefore i am a hamster.
Capture 1080i50 with minimal quality loss. Advice please!
By nick1977 in forum Capturing and VCRReplies: 40Last Post: 28th Apr 2018, 19:23 -
Want to covert a single MKV into smaller MKVs with zero loss in quality.
By boe in forum EditingReplies: 10Last Post: 29th Dec 2016, 18:13 -
High end (minimal loss) converter? (CineForm)
By fabes253 in forum Video ConversionReplies: 20Last Post: 11th Apr 2015, 01:54 -
Video size reduction with minimal quality loss?
By johnrichards in forum Newbie / General discussionsReplies: 7Last Post: 26th Feb 2015, 01:31 -
How to convert AC3 5.1 into DTS 5.1 with minimal quality loss ?
By Hitesh12 in forum AudioReplies: 4Last Post: 11th Jan 2015, 08:20
