when i am converting avi or mpg files to vcd mpg format i have been using tmpgenc. it has been working really well apart from 2 files i have. the first works perfectly in windows media player but when i try to encode it with tmpgenc it wont let me. it has the following properties (encase it matters):
bit rate: 32kbps
audio sample size: 4 bit
audio format: micosoft adpcm
frame rate: 23fps
data rate: 31kbps
the second file which i downloaded from morpheus doesnt load in windows media player or tmpgenc saying that the codec required is not found. it has the following properties:
bit rate: 8kbps
audio sample size: 16 bit
audio format: windows media audio v2
frame rate: 15fps
data rate: 39kbps
i have also tried importing them into premiere 6 but it wont allow me to do that either. if anybody knows what may need doing please let me know. thanks
martyn
Results 1 to 1 of 1
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Converting VOB files to Mpg..
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 22:27 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
plan for converting SageTV mpg's to smaller files.
By Verlager in forum LinuxReplies: 7Last Post: 6th Feb 2008, 22:56 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 01:01
