hi
I'm using VSDC.
I added an image to my scene.
I then added to the image several linked "movement" animations.
i.e., the first movement lasts a second and the object slides up. the 2nd movement starts immediately after the first movement, lasts a second, and slides to the right, etc
In the preview, it works fine.
But when I in the export, it doesn't work properly.
It's as if it takes the start point of the first movement and moves the object to the end of the last movement point and ignores all intermediary movement points.
I'd appreciate any help
thanks
Hate to bump an old thread but I've ran into this exact same issue and can't figure it out. The movement flows great in the preview but once I export there's no movement.
VSDC export
By Čamo in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2019, 05:59 -
Is it possible to export only part of a video in VSDC ?
By johan22 in forum EditingReplies: 3Last Post: 12th Oct 2017, 12:06 -
VSDC video editor export problem: How do I cut the unwanted extra duration?
By T111 in forum EditingReplies: 1Last Post: 7th Mar 2017, 18:08 -
VSDC Free Export Problems
By swede1128 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2016, 12:28 -
VSDC Exporting Issues - Can Someone help me export?
By INsupps in forum EditingReplies: 8Last Post: 12th Nov 2015, 12:15
