Hi, so here's my question, is it possible to like rip appart an element, such as a picture or anything really. Which effect should be used, how ?
If I have a picture for example and I want to make it rip appart and fall on the bottom of the screen for example, I don't know how to do such a thing but I would like to.
Vegas is mainly a video editor - so not really.
Or it won't look realistic or very good. To do this properly , you would usually use a 3D program and a cloth or physics simulation . You can import that into vegas to edit as part of your main project
But it depends what you had in mind exactly. "rip apart a picture" implies something thin, like cloth or paper . Not an object like a car
You can use alpha channel mattes, as pre-rendered cloth tearing simulations, that you can import into vegas - but it doesn't look very realistic, and it might take awhile to find one you exactly like that "falls to the ground" and stays there, instead of disappearing. You can find rendered "tear transitions" on various sites to purchase .
Sony Vegas Pro - Typography Tutorial 2
By mo7amed3rf4n in forum User guidesReplies: 0Last Post: 25th Jun 2016, 10:28 -
Sony Vegas Pro 10.0 (weird UI bug)
By deadlys in forum EditingReplies: 5Last Post: 29th Feb 2016, 19:22 -
Help me!!!!! (SONY VEGAS PRO 13.0)
By Tengzy in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2015, 22:48 -
Tiles in Sony Vegas Pro
By zoobie in forum EditingReplies: 15Last Post: 31st Mar 2015, 16:16 -
Sony Vegas Pro 13 problem!
By Gamestukki in forum EditingReplies: 3Last Post: 4th Mar 2015, 10:14
