Hello,
Another user of these forums and I have a question about digitized video from VHS (PAL and NTSC), captured with a Canopus device in DV. It refers to the typical noisy overscan lines in the bottom (3 or 4). How can these lines be blackened, padded, without reencoding the file format, that is, just by text-editing the video header? We both use Macs.
I have used Atom Inspector to do some things, with some success. Atom Inspector does not take DV-wrapped files, so first I have to re-wrap the .DV file as .MOV without reencoding. Perhaps this padding can be done in the Clap settings? The point, again, is to leave the full range of horizontal lines (480 in NTSC, 576 in PAL), but to define the last 4 or so as black or padded.
And then, would this setting carry on to apps to convert the DV-format file, such as Avidemux?
Thank you!
				Results 1 to 1 of 1
  Removing weird lines over a lot of the video?By killerteengohan in forum RestorationReplies: 13Last Post: 15th Feb 2019, 21:05
  Removing VHS color lines and restoring a cartoonBy bmick23 in forum RestorationReplies: 3Last Post: 2nd May 2016, 05:28
  [SOLVED] FFmpeg: Removing Black lines from VideoBy VidElp in forum Video ConversionReplies: 3Last Post: 23rd Aug 2015, 14:32
  Green lines on captured video fileBy nusratjaveid in forum Capturing and VCRReplies: 6Last Post: 20th May 2015, 14:08
  Removing lines from video?By killerteengohan in forum RestorationReplies: 42Last Post: 21st Nov 2014, 16:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
