I have MKV file that contains AVC h264 video file and I would like to convert it to MPEG-4 XviD AVI file. Which free software would allow me to do that?
Results 1 to 10 of 10
Does anyone know if it's possible to set MPEG4 XviD Advanced Simple to Level 5 in Xmedia Recode?
MPEG-4 Xvid (MPEG-4 Part 2) is ASP (Advanced Simple Profile). Level 5 is used in AVC (MPEG-4 Part 10)(AVC Levels) so your post makes no sense to me. -
[Attachment 48892 - Click to enlarge]
I opened Mediainfo for a video file and it shows that's it L5 (I'm assuming it means Level 5), but when I convert video file to MPEG4 XviD AVI but it shows L1. -
If the program gives you acces to the Xvid codec's configuration dialogs you can specify the Profile@Level:
[Attachment 48893 - Click to enlarge]
Otherwise try using VirtualDub2 which gives you access to the configuration dialog. -
Really? It seems that most of AVI video is encoded by XviD or DivX codecs. So are you sure the mpeg-4 avi is your desired result?
Xvid and Divx are MPEG 4 Part 2 codecs. AVC/h.264 are MPEG 4 Part 10. Ie, they're all MPEG 4 codecs.
prevailing best method for converting .mp4/avc&aac into .mkv/avc&mp3 ?
By hydra3333 in forum Video ConversionReplies: 6Last Post: 31st Dec 2017, 20:24 -
PAFF H264/AVC encoding
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2016, 16:42 -
Edit and join AVC and MPEG-2 files, export to MKV with AviSynth, MeGUI
By svenssonsven8 in forum Video ConversionReplies: 5Last Post: 30th Oct 2015, 13:09 -
Mpeg-4 (h264 - MPEG-4 AVC) batch time-based splitting tool for Windows
By jokob in forum EditingReplies: 3Last Post: 4th May 2015, 20:26 -
Playing H264 - MPEG-4 AVC (part 10) (h264) Stream
By SamirD in forum Software PlayingReplies: 1Last Post: 13th Jul 2014, 13:50
