I have a video that is 29fps and is 720p resolution. I would like to know how to deinterlace this in handbrake and get it to 50fps that looks super smooth like this video here https://www.youtube.com/watch?v=uJiG3SJCFaM . What settings do I need to apply ? to achieve this thank you
	Are you sure it's 720p? Or is it just 720 pixels wide?
 If you were actually working with 29.97fps interlaced footage (not progressive as you said), you would want to go to 59.94fps in Handbrake (double the original), not 50fps.
 The video link you posted has the other settings they used right in the title (deinterlaced decomb eedi2bob default). If your footage is in fact interlaced, and you want to mimic the settings used in that video, you would just select those in the filters tab. Then change frame rate to 59.94 constant. Pick a CF quality of 18 (or whatever you want). There are a few other quality settings and speeds you can select but that's the basic gist, to answer your original question, assuming your footage is actually interlaced (otherwise why would you be asking how to deinterlace it, right?)
	I don't know why anyone would want to emulate that YouTube video to begin with. Just look at all the shimmering going on, especially of the railings on the right side at the beginning.
  Audio pitch after video is convert using handbrake or video coderBy Freelife2345 in forum AudioReplies: 3Last Post: 9th May 2016, 03:33
  I have a mp4 file that is 720p @ 50fps I want to convert it to a PAL DVDBy jjcinema1 in forum Newbie / General discussionsReplies: 6Last Post: 20th Apr 2016, 07:52
  Best option to convert 1080i 50fps to 1080p 25/30By Fadedown in forum Video ConversionReplies: 2Last Post: 26th Aug 2015, 11:35
  Convert 1080i ts to 720p/50fps mkv with AviSynth and QTGMCBy svenssonsven8 in forum Video ConversionReplies: 6Last Post: 2nd Sep 2014, 11:48
  Bd Rebuilder ,Can convert 1080p 50fps to 25fps?By ningnong132 in forum Video ConversionReplies: 12Last Post: 14th May 2014, 12:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
