I understand this topic has been discussed to death, but I read many articles and I can't seem to find the answer.
So my monitor is set at RGB Full. On my PC, I can use the nvidia control panel to choose whether the output is to be RGB Limited or RGB Full. Guides tell me to use RGB Full because I am using a PC monitor.
Here's the problem: When I watch TV shows/Movies on my PC, using either VLC player or MPC-BE + madvr, RGB full feels wrong. Dark scenes are so dark you can't see a lot of things. I understand that TV shows are made in RGB limited range, so I should be using RGB limited setting in nvidia whenever I watch shows. However, I also play a lot of games, does that mean I have to switch to RGB full everytime I want to play games, and switch back to watch shows? That is my conclusion at least.
Here's why it doesn't make sense: I am a noob at this, but if I understand correctly, I should just leave the settings at RGB full. If a video is meant to be played back in Limited color space, shouldn't playing it back using Full settings on a Full monitor be perfectly fine? No scaling even needs to be done right, the limited color range can be displayed on a full color monitor? Yet the dark scenes of the show look so much darker when using RGB Full.
Does anyone know what I should do? Full or limited, or maybe it's the video player/nvidia's fault?
This may look easy at first, but it is very complicated. Please read madshi's FAQ first:
Which output format (RGB vs YCbCr, 0-255 vs 16-235) should I activate in my GPU control panel?
What hardware like GPU, Monitor do you use? -
GPU: Nvidia 750 TI
Monitor: HP 23es https://support.hp.com/sg-en/document/c05076790
One thing I don't really understand though. For Full, black is at 0, for Limited, black is at 16. If everything is set up properly, is 0 on a Full setup the same color as 16 on a Limited set up?
Thank youLast edited by attackworld; 24th Apr 2019 at 22:08.
Urgh, so after making sense of all that, basically it is okay to keep control panel settings as 0-255 despite videos being in 16-235 because the computer will take into account for that? Like the numbers will be stretched accordingly so the color remains the same?
Panasonic NV-HS860 and others in that range
By Quasipal in forum RestorationReplies: 11Last Post: 16th Sep 2018, 09:40 -
RGB to YUV to RGB
By chris319 in forum ProgrammingReplies: 70Last Post: 20th Feb 2017, 16:49 -
Color Range Question
By Akai-Shuichi in forum RestorationReplies: 4Last Post: 14th Feb 2017, 15:53 -
x265 bitrate range
By nixiejames in forum Video ConversionReplies: 10Last Post: 29th Feb 2016, 14:18 -
YV12 to RGB converter?
By synnchan in forum Newbie / General discussionsReplies: 12Last Post: 28th Jun 2014, 20:45
