Results 1 to 21 of 21
  1. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    Dear All
    I am beginner in the adjustment of the video files
    I want to merge to the video file cover, font, subtitle and remove what in the original file has
    of course this is easy if I have one or two but I have here anime still running and for now it is 80 episodes so how I can change for all folder?
    the single file changing will be as below, at window CMD.exe
    "C:/Program Files/MKVToolNix\mkvmerge.exe" --ui-language en --output ^"D:\sample\01.mkv^" --no-subtitles --no-attachments --language 0:und --default-track 0:yes --language 1:jpn --default-track 1:yes ^"^(^" ^"D:\example\01.mkv^" ^"^)^" --language 0:und ^"^(^" ^"D:\example\01.ass^" ^"^)^" --attachment-name ^"adobe arabic.ttf^" --attachment-mime-type application/x-truetype-font --attach-file ^"D:\Attach\adobe arabic.ttf^" --attachment-name cover.jpg --attachment-mime-type image/jpeg --attach-file ^"D:\Attach\cover.jpg^" --track-order 0:0,0:1,1:0
    please note that I used (MKVBatch) but it didn't deal correct and some files went totally wrong in addition the correct files has no attachments
  2. I would like to help you, but it is not allowed to deal with warez.
    I'm pretty sure this thread is closed very soon.
    My personal advice: don't use suspicious filenames and directories
  3. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    please explain to me ? I don't understand whats the not allowed? I am trying to merge subtitle language to video file so i can watch and understand
    if you like i will change everything to example n sample
  4. Don't make it obvious you're talking about illegally downloaded videos by showing "Torrent" and the series name in your example command line.
  5. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    fixed
    please help
  6. Originally Posted by ghazalo View Post
    https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
  7. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    fixed
    please help
  8. Example for remuxing mkv files and ass files with matching filenames in one folder.
    create *.bat file with following code:
    for %%a in (*.mkv) do ("C:\Program Files\MKVtoolnix\mkvmerge.exe" -o "D:\new\%%~na.mkv" "%%~na.mkv" "%%~na.ass")
    place that file in folder with files and execute, the muxed new files are saved to D:\new, of course you can change that.
    For your special needs, just extend the bat with language selections and attachments.
  9. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    thanks
    what about the attachments?
  10. I need more info for that, is that stuff already in the source mkv or is it a external file? What kind of attachments?
  11. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    there is English sub and font attached I want to remove
    and there is Arabic font and cover I want to add from external folder called attach
    this is the single file exact changing from MKVtoolnix I want to make the same for whole folder
  12. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    check the photos for single file changes
    thanks
  13. To summarize for me, there are about 80 files in a folder and each file contains an english font, which should be removed and in a separate folder there is a cover and a font, so two files which should be added to each file?
    I am from bavaria and sleep for the next hours, in the meantime upload a file and the separate files to google drive or similar (personal space) and pm me the links and I take a look at it tomorrow. It‘s better to test it when creating that bat file stuff.
  14. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    ok thanks
    have a nice night
    also take your time a I am not in a hurry
    To summarize for me, there are about 80 files in a folder and each file contains an english sub + font, which should be removed and in a separate folder there is a cover and a font, so two files which should be added to each file?
    yes as you said thanks
  15. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    link for 1 file of 80
    thanks
  16. Please remove the link as fast as possible, link only as pm -> private mail.
    Otherwise the thread might be closed.
  17. I have the zip file already downloaded
  18. At first create a remove sub and attachment.bat file which contains
    for %%a in (*.mkv) do ("C:\Program Files\MKVtoolnix\mkvmerge.exe" -o "removed subtitle and attachment\%%~na.mkv" --no-subtitles --no-attachments "%%~na.mkv")
    This creates a subfolder removed subtitle and attachment with all new files without any attachments and subtitles
    Then create a bat file which contains
    for %%a in (*.mkv) do ("C:\Program Files\MKVtoolnix\mkvmerge.exe" -o "muxed\%%~na.mkv" --attachment-name "adobe arabic.ttf" --attachment-mime-type application/x-truetype-font --attach-file "D:\project\Attach\adobe arabic.ttf" --attachment-name "cover.jpg" --attachment-mime-type image/jpeg --attach-file "D:\project\Attach\cover.jpg" "%%~na.mkv" --language "0:ara" "%%~na.ass")
    This creates a new subfolder muxed which contains new muxed files with the new arabic ass subtitle set as arabic language and both attachments in the files.
    Done
  19. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    thanks a lot
    I will try and update you
  20. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    it works great thank you very much indeed
    you make my life easier watching long series on my TV screen
    thanks again
  21. Member ghazalo's Avatar
    Mar 2015
    Riyadh
    thanks i found how
