Hello,
I have been trying to exchange an English language audio for a Russian language audion, in a video file. The file is in MP4 format with a coanstant rate video and variable rate audio. I take a constant rate audio from a different file and try to insert the audio track into the video file, effectively exchanging the Russian audio track for an English audio track. The audio begins synced but quickly de-syncs. The duration of video and audio are identical. I use ffmpeg or Avidemux.
Currently, I'm using Handbrake to make a copy of the film with a constant rate audio track which I can then use. This will take about eight hours.
Is there a quicker way, using ffmpeg?
Is the variable nature of the audio track embedded in the video file, thus requiring conversion of any audio track candidate into a variable audio track?
To re-phrase, if a video (constant bit rate) has an audio with variable frame rate, must any substitute, also have a variable bit rate?
Thank you
Audio "rates" that are referring to are data birates: cbr, vbr, abr. Audio does not have a framerate in the sense that video does, so it will NOT have a variable samplerate. EVER. If it did, you would know immediately, because it would have horrible pitch problems (wow, flutter, warbling, etc).
Audio data rates DO NOT affect its runtime, sync, or anything else time-related so if you are having issues with syncing, it is probably due to some other issue: different video lengths, edits, non-matching timebases (using 30 when you should be using 29.97).
Give us more info.
Scott -
Hello,
Thanks for responding.
I'm using MediaInfo for metadata retrieval. The original video data:
===================== Video =====================
Format : AVC
Format info : Advanced Video Codec
Formatprofile : High@L5.1
Formatsettings, CABAC : Yes
Formatsettings, ReFrames : 4 frames
Codec Id : avc1
Codec info : Advanced Video Coding
Duration (ms) : 2h 33mn
Bit rate : 22.9 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.115
Stream size : 24.5 GB (99%)
Tagged date : UTC 2017-10-13 14:47:40
Menus : 0
===================== Audio =====================
Format : AAC
Format info : Advanced Audio Codec
Formatprofile : LC
Codec Id : 40
Duration_FirstFrame : 18ms
Duration_LastFrame : -10ms
Bit rate mode : Variable
Bit rate : 243 Kbps
Maximum bit rate : 249 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 266 MB (1%)
Default : Yes
Alternate group : 1
Menus : 0
The data for the file from which the audio is extracted is:
Format : AVC
Formatprofile : High@L3.1
Formatsettings, GOP : M=1, N=72
Codec Id : avc1
Duration_FirstFrame : 46ms
Bit rate : 2 164 Kbps
Width : 1 280 pixels
Height : 532 pixels
Display aspect ratio : 2.40:1
Original display aspect rat : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.132
Stream size : 2.30 GB (91%)
Writing library : x264 core 152 r2851 ba24899
Encoding settings : cabac=1 / ref=4 / deblock=1:2:2 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=17 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=72 / keyint_min=7 / scenecut=0 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2164 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=0.91 / aq=1:1.00
Tagged date : UTC 2018-07-07 17:27:51
Format : AAC
Formatprofile : LC
Codec Id : 40
Duration_LastFrame : -4ms
Bit rate mode : Constant
Bit rate : 204 Kbps
Stream size : 224 MB (9%)
Default : Yes
Alternate group : 1
The audio section, in each file, refers to a "Bit rate mode", this is what I am quoting. -
Right. Hence my 2nd paragraph.
If you want to compare them put both audio streams in a DAW. Then you'll know whether they should sync or not. If they do, then there is something faulty with your re-encoding and/or re-muxing process. If they don't sync, you have editing or time compression/expansion to do first to get them into sync.
Scott -
Hello,
Thanks.
I loaded both sound tracks into Audacity and both were synchronized.
I use ffmpeg and Avidemux, which also uses ffmpeg, I believe. I had to download a converter to convert the aac format to wav for use with Audacity.
Every time I've encountered a video with a variable bit rate audio, I've encountered this sync problem.
Any suggestions for software to replace ffmpeg?
Thank you
Retrieve subtitle file embedded in an MP4 video
By kasfig in forum SubtitleReplies: 5Last Post: 20th Feb 2019, 22:27 -
video has compressed and distorted audio and jerky frame-rate
By kamalakar108 in forum Video ConversionReplies: 12Last Post: 5th Feb 2018, 22:22 -
MP4 video files on DVD, keeping bit rate above source
By Much2Learn in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2016, 22:23 -
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 8th Aug 2014, 00:10 -
Desynchronization between audio and video with the same frame rate. Help!
By kenobi88 in forum AudioReplies: 3Last Post: 6th Aug 2014, 23:41
