Hi;
i am new to home theater setup, just bought one (Samsung) and set it up, but now when i go to videos in dvd player menu, it doesn't show mkv files in the folders..
so how can i play mkv files on dvd player??
do i have to convert them??
how you guys play mkv movies downloaded from INTERNET on your home theater???
thanks in advance for all your input.
You can't play any mkv files on a dvd player,you will have to buy a blu-ray player to play mkv files.
thanks for your input.
now what are the solutions available for me? as you said i should buy bluRay player and that is not possible now.
Can i convert from mkv to any other format like mp4 or avi and will it play?
if yes, wont i loose video or audio quality? and what parameters i should choose for optimal result.
can i use android box for playing mkv files (offcourse with sound coming from home theater speakers)?
or any cheap (in therms of cost) solution..? -
- My sister Ann's brother
If its a DVD player try avi with xvid video and mp3 audio. Without a model number can't help much more. My Curtis doesn't have mpeg4 documented but it does indeed play them.
if all else fails read the manual -
Samsung Bluray player e5300 - MKV files (as data) - CINAVIA
By chochanga in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Jan 2018, 14:29 -
BluRay player won't play certain MKV/MP4 files
By Dan091 in forum Newbie / General discussionsReplies: 13Last Post: 22nd Mar 2016, 02:28 -
Some mkv files and some MP4 will not play on BR player
By Abel Magwitch in forum DVD & Blu-ray PlayersReplies: 10Last Post: 18th Feb 2016, 04:19 -
Samsung F5100 cannot play MKV Files (size >4gb) burned on Bluray/DVD Disc
By K.S.LEE in forum Newbie / General discussionsReplies: 9Last Post: 5th Sep 2014, 01:34 -
Blu-ray player that will play MKV files off a BD-R?
By ampex in forum DVD & Blu-ray PlayersReplies: 12Last Post: 31st Aug 2014, 00:53
