    Jan 2006
    Argentina
    Hi,
    can someone please tell me how to solve this error?
    ------------------------- Error opening source -------------------------
    AVISource: couldn't locate a decompressor for fourcc XVID
    (G:\Case Sensitive S01 [2011]\Case Sensitive\Case.Sensitive.S01E01.HDTV.XviD-BiA_temp\Case.Sensitive.S01E01.HDTV.XviD-BiA_source.avs, line 1)
    AviSource("G:\Case Sensitive S01 [2011]\Case Sensitive\Case.Sensitive.S01E01.HDTV.XviD-BiA.avi", Audio = False)
    Until version 1.9.0.0 worked without problems. But as of version 2.0.0.0 onwards, this error is produced.
    I wait your answer.
    Thank you. Best regards.
  2. It's telling you exactly what's wrong: you need a VFW Xvid codec. Be sure to install a 64 bit version for 64 bit Staxrip.
    Jan 2006
    Argentina
    Hi, again.
    I attach the status of the installation of xvid_encraw.
    And I keep giving the same error.
    I also tried copying the codec from version 1.9.0.0 and it does not work either.
    Any other suggestions?
    Thank you.
    Mar 2008
    Looks to me like you need an xvid decoder to source the frames; xvid_encraw is the xvid encoder
  5. Member stax76's Avatar
    Nov 2009
    On thin ice
    Exactly that, I've changes this recently to use a built in decoder instead.
