I do have libfftw3f.3.dylib installed. If I try to load it, instead of libmvstools.dylib, this is the error:
Failed to evaluate the script:
Python exception: No entry point found in /usr/local/lib/vapoursynth/libfftw3f.3.dylib
File "src/cython/vapoursynth.pyx", line 1937, in vapoursynth.vpy_evaluateScript
File "src/cython/vapoursynth.pyx", line 1938, in vapoursynth.vpy_evaluateScript
File "/PATH/tempPreviewVapoursynthFile01_15_54_503.vpy", line 6, in
File "src/cython/vapoursynth.pyx", line 1843, in vapoursynth.Function.__call__
vapoursynth.Error: No entry point found in /usr/local/lib/vapoursynth/libfftw3f.3.dylib
But if I add the two lines in this order:
core.std.LoadPlugin("/usr/local/lib/vapoursynth/libfftw3f.3.dylib")
core.std.LoadPlugin("/usr/local/lib/vapoursynth/libmvtools.dylib")
this is the error message:
File "/Users/celso/DOCUMENTOS/VÍDEO/TEMP/HybridTest/tempPreviewVapoursynthFile01_15_54_503.vpy", line 6, in
That is, I'm not sure whether the script stops and it doesn't load libmvtools.dylib, or it does load it, in which case the problem with be libfftw3f.3.dylib .
I'll check into doom3, even all this is really beyond my knowledge. I wish there were just a simple Mac to be able to use QTMGC, which is all I want at this point. I might try vapoursynth for Windows in a virtual machine, but that would slow video processing even more.
Thank you very much again.
-celso
Results 31 to 41 of 41
Do you have all the dependencies ? Did you read that whole mac thread ? post 23, 24 ?
kolak copied them and he said it worked for him
l33tmeatwad:
To be completely specific about every dependencies you need, you will need links or copies of the following in /Library/Frameworks/VapourSynth.framework/lib:
libfftw3f_threads.3.dylib
libfftw3f.3.dylib
libgcc_s.1.dylib
libstdc++.6.dylib
kolak:
I have those libs. Lets see if copying yours will fix it.
update: it's working now with your libraries. It's very possible it would work with main also, but I had missing dot in one of the names! -
I have no more ideas . Your best bet is to ask there , since there are a handful of active vapoursynth mac users there
These types of issues occur on windows too, both avisynth and vapoursynth, but the greater number of users means help and support is much better -
Thank you very much indeed. I managed to install ffwt3 (brew install ffwt, or whatever) and now the script loads those plugins, though I get this error
Error: znedi3: error reading weights
Well, I think it's an improvement, just have to fix that znedi plugin! I'll keep researching.
-celso -
Do you have the nnedi3_weights.bin file ? You need it for nnedi3 , or any of the derivatives like znedi3
https://github.com/dubhater/vapoursynth-nnedi3/blob/v6/src/nnedi3_weights.bin
Also, if you can document how you "fixed" or installed something, it might help other mac users -
It has to be in the same path , so wherever you have your plugins or linked libaries
Cheers
"Pay it forward" and don't forget to help out the next guy having problems -
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2357Last Post: 1st Aug 2025, 05:32 -
AviSynth with ffms2 and l-smash on Ubuntu
By Valit in forum LinuxReplies: 19Last Post: 22nd Feb 2019, 15:37 -
How to use 64bit avisynth plugins in vapoursynth with the Eval function?
By danfgtn in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2019, 14:08 -
Can i use AviSynth plugins in vapoursynth?
By zanzar in forum Newbie / General discussionsReplies: 16Last Post: 13th Feb 2019, 08:37 -
Avisynth equivalent plugins for vapoursynth
By zanzar in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2019, 11:58
