  1. I'm trying to cut out a simple video clip lasting a few minutes.
    When I copy a .ts file into Avidemux and press play, I get video, but no audio.
    When I copy an .mp4 file into Lossless Cut and press play, I get video, but no audio.
    This happens whether the video file length is 5 minutes or 3 hours - file size seems to be irrelevant.
    Playing the same files in VLC Player or any other video player, I get video and sound.
    If I use either Avidemux or Lossless Cut to cut out and save a clip, the clip itself has both video and audio, but I have to guess where to set the markers by reading lips on the video. I've had IT check Windows 10, device manager and the drivers or anything else in the OS and everything checks out fine with the OS. Does anyone have any idea why I can't get audio when i play .ts or .mp4 files in these video editors??
    Mar 2008
    In Avidemux edit/preferences/audio
    check downmix and device
  3. Dave,
    Thank you so much! Changing device from 'Dummy' to 'Win32' in Avidemux fixed the problem right away. Much appreciated.
    Anyone else know of a similar fix for LosslessCut?
    Dec 2006
    Just want to thank Dave, too, as I struggled so long with this on Avidemux that I had just given up and accepted I had to guess with the audio. It's like being given my hearing back!
    Aug 2020
    netherlands
    I have also a problem with no audio in Avidemux.
    edit/preferences/audio are set properly
    downmix: Prologic or stereo
    device: Win32
    But in the main screen it states:
    audio output: 0 tracks
    When I play the source mpg file in for instance GOM player, it definitely has audio.
    What could be the problem?
