Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 28 of 28
  1. whats best program to do this
  2. Originally Posted by jagabo View Post
    depends
    on what ?
  3. Container, codecs, playback restrictions, do you care how long it takes, etc.
  4. Originally Posted by jagabo View Post
    no I am in no hurry
    anyone here knows as Im not getting any feedback
  5. Maybe if you provided the information suggested by jagabo...
    You can begin by showing the Text printout of what MediaInfo says about your movie. It's found in View->Text.
  6. Well, "What?" and "Why?" might give a bit more info to work with. (I'm afraid the telepathy-blocker add-on on this browser is just too darned effective!)
    canada
    Use vidcoder and set the bitrate to a lower value and encode as mkv or mp4,also research bitrate sizes so you know what size you want.
  8. Originally Posted by jagabo View Post
    Apologies I didn't realise you needed info regarding the above I just thought you was pointing out those things. I have now checked with mediainfo its only short movie clips anyway
      General
    Complete name                            : C:\Users\stan\Videos\Farming Simulator 2019\Farming Simulator 2019 2019.04.19 - 14.25.18.12.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (isom/mp42)
    File size                                : 737 MiB
    Duration                                 : 2 min 40 s
    Overall bit rate                         : 38.6 Mb/s
    Recorded date                            : 2019
    Encoded date                             : UTC 2019-04-19 13:28:00
    Tagged date                              : UTC 2019-04-19 13:28:00
    Video
    Format profile                           : High@L4.2
    Format settings                          : CABAC / 1 Ref Frames
    Format settings, RefFrames               : 1 frame
    Format settings, GOP                     : M=1, N=30
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Source duration                          : 2 min 40 s
    Bit rate                                 : 38.4 Mb/s
    Width                                    : 1 280 pixels
    Height                                   : 1 024 pixels
    Display aspect ratio                     : 5:4
    Frame rate mode                          : Variable
    Frame rate                               : 58.260 FPS
    Minimum frame rate                       : 6.635 FPS
    Maximum frame rate                       : 63.739 FPS
    Original frame rate                      : 60.000 FPS
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.503
    Stream size                              : 733 MiB (99%)
    Source stream size                       : 733 MiB (99%)
    Title                                    : VideoHandle
    Color range                              : Limited
    Color primaries                          : BT.601 NTSC
    Transfer characteristics                 : BT.470 System M
    Matrix coefficients                      : BT.601
    mdhd_Duration                            : 160011
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Duration                                 : 2 min 39 s
    Source duration                          : 2 min 39 s
    Bit rate mode                            : Constant
    Bit rate                                 : 192 kb/s
    Nominal bit rate                         : 96.0 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 3.72 MiB (1%)
    Source stream size                       : 3.72 MiB (1%)
    Title                                    : SoundHandle / System sounds
    mdhd_Duration                            : 159937
    manono
    Re: changing bitrate on a movie
    thanks
    johns0
    Thank you
  9. Originally Posted by johns0 View Post
    How do you set bitrate to lower as I cant see where
  10. In Vidcoder go to the Encoding Settings dialog. In the Quality section set Target Size or Avg Bitrate. Keep in mind that the smaller you make the file the lower the quality is going to be.
    If you have playback restrictions, like you're making a DVD, the procedure will be very different.
    Im a bit confused as I want this clip to show on youtube as its ok on my PC but on UT its on at 360. also the video says in snapshot above bit rate is 38.4 Mega Bits per second
    but in this snapshot of Vidcoder its saying target size 20 MB Average Bitrate kbps 900 so Im lost now
  12. You've chosen Target Size. The Avg Bitrate setting no longer applies.
  13. Originally Posted by jagabo View Post
    ok i have now choosen Avg BitRate which says kbps how do i know what number to put there for my video to be 1080
  14. well on youtube it says this as when I uploaded mine all I got was 360 my monitor is 1280 x 1024
  15. What frame size did you upload to Youtube? Post a MediaInfo report on the file you uploaded.
  16. Originally Posted by jagabo View Post
    its above in reply 10 the mediainfo
  17. Originally Posted by foldbck123 View Post
    There's nothing in post #10. You mean post #9? That is your source video, not the video your converted video.
  18. Originally Posted by jagabo View Post
    Yes sorry reply 9.
    But I have not converted the video with VidCoder as dont know what to do with it
  19. So you uploaded that 1280x1024 video but only got a 360p video at youtube? Did you wait long enough? As I understand it, Youtube doesn't make all versions available at once. It can take quite a while (hours?) for higher res versions to show up.
  20. Originally Posted by jagabo View Post
    Oh I see well the quality of the video was real bad 360. so why do youtube make you wait for hours when others need to see high quality
  21. Originally Posted by foldbck123 View Post
    Because it takes longer to create the higher resolution videos. And they're converting many thousands (?) of videos at the same time.
  22. Originally Posted by jagabo View Post
    oh well waste of time then uploading a video for someone to watch and its low quality 360 when before its ok
  23. Originally Posted by foldbck123 View Post
    Where are you getting that idea? Just wait a few hours or days for the higher res videos show up at youtube.
  24. Member Cornucopia's Avatar
    Seems to me from your pic that you chose "auto" and it chose 360. It likely does that based on your available bandwidth, so if your DL bandwidth is reduced, 360 may be the only thing it thinks will be reliable.
  25. Originally Posted by Cornucopia View Post
    Yes, that's a good point. You can use youtube-dl to see all the versions that are available.
  26. And since it's 1280x1024 (a very odd resolution), he can wait till hell freezes over and he'll never get 1080p on YouTube. At most, he might get 720p.
    Was it upscaled from PAL DVD by an idiot?
