Hi. So I downloaded XVid and installed it in my PC. Then my anti-virus (Avast) detects the Update file of XVid as IDP Generic (which I know it's not a real virus and is bullshit) so I restored the file and tried to uninstall XVid so I can re-install it. However all the time I try both the installation and the un-installation, at some point it says: Installation failed. How can I deal with this?
Where did you download it from ?
Been a long time since I installed/ran this and TBH it is quite old now even tho the most recent version is only some 2 years previous.
Certainly do not recall any updater.
Try a direct download from this site unless that is the one you refer to.
https://www.videohelp.com/software/XviD-Codec -
I downloaded it from the official XVid website. There is a script file called CheckUpdate and another file called CheckUpdateLauncher. These two, my Avast antivirus recognizes as IDP Generic (which is a false positive and not really a virus), so I restored the files. But then I uninstalled and it tells me Installation Failed. Then it kinda uninstalls, but I re-install and near the end of the Installation process, it says "Installation Failed" when it gets to "Creating xvidhomepage".
Xvid-1.3.5-20171208.exe ? That's odd I just downloaded from www.xvid.com and checked it
with virustotal.com, didn't find anything
https://www.virustotal.com/#/file/af52b058ae294a3f8bc0d65ea2f93f30cd847be2b2307f194544...ae04/detection -
I know it doesn't have any viruses, but it's the problem with the Avast Anti-virus that it recognizes some files as IDP Generic, when they really do not pose any threat.
I guess that neither of those files are critical. Maybe your AV does not like scripts that 'phone home' since some could well be problematic.
You might have to do a manual uninstall. Delete folders/files and registry entries. Or just the folders/files and try to install again. Maybe even turn the AV off during the installation.
Xvid 1.3.4 (VFW)
By El Heggunte in forum Video ConversionReplies: 4Last Post: 15th Dec 2017, 12:42 -
Converting XVid to MP4 problems with handbrake
By PowerFalcon in forum Video ConversionReplies: 11Last Post: 31st Mar 2016, 03:59 -
Problems Demuxing, Remuxing and Encoding AVIs. Also MeGUI problems.
By VideoFanatic in forum RestorationReplies: 1Last Post: 10th Feb 2016, 02:30 -
Xvid 1.3.3 (VFW)
By El Heggunte in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2015, 07:29 -
Time lapse in Vdub. Problems with large file size and x264VfW problems
By nab49 in forum Newbie / General discussionsReplies: 18Last Post: 24th Sep 2014, 16:52
