Hi,
I have several Hi8 tapes from the 20e centuryand can borrow a 8mm camera to play the tapes and record it with software on the disk of my laptop. My question is whether I need to have a Hi8 camera instead of a 8mm camera to get the best quality picture as possible? Of is the 8mm camera OK and so enough.
anyway suggestion(s) is welcome!
Thanks for the response.
If these Hi8 tapes were recorded with a Hi8 camera, then yes you really need a Hi8 or Digital8 camera. Back in the day, you could record normal Video8 video on Hi8 tapes, which means it could be played back on a Video8 machine. But if it's Hi8 video on a Hi8 tape, then a Video8 machine won't be enough.
Hi Karma, thanks for the response. I am going to look for a Hi8 camera. Do you have so a suggestion for simple free recording software to get the video on the PC. I bought a set, software and cable, at a super market for 18 dollar. It works fine but any suggestion is welcome
AmaRecTV or Virtualdub. I'm a former Virtualdub user but after having to deal with the well know audio shifting, I moved to AmaRecTV which doesn't have the same problems. Use Amarectv 2.31 over the newer one.
Can I record Hi8 quality on video8 tapes?
By chinhang899 in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2017, 04:00 -
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 12:34 -
Is it possible to find out if Hi8/8mm tapes were recorded in stereo?
By CZbwoi in forum MediaReplies: 20Last Post: 20th Apr 2016, 23:10 -
Best way to capture Hi8/8mm tapes
By Sir_Loin in forum Capturing and VCRReplies: 4Last Post: 17th Mar 2016, 05:35 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 18:39
