Hi,
I have around 100 Mini DVs, which I have to transfer to DVD
Now I'm searching an easy way to process the captured DV files to authored DVDs (in fully automatic toolchain).
My dream:
I select a DV file (or more) and enter a title, pressing "Go", waiting some time.... and get at the end a DVD like this:
- a Menu which includes the given title
- a authored DVD with maximum possible Bitrate (for a 4,7GB DVD)
- very high quality video
- NO chapters needed
- DON'T need burning. a VIDEO_TS folder is fine
1. anyone knows a good way to set up a toolchain like this (windows or linux). Or is there maybe already a out-of-the-box solution avialable?
2. ffmpg can be used as command line. Is the ffmpg mpeg2 encoder quality any good? For example comparable with Mainconcept or CCE ?
DVavi helper.zip can do that, drop your DV.avi onto makeDVD.BAT and it will create VIDEO_TS,
change defaults in settings.BAT,
read that "read first.txt" file, that VIDEO_TS should be in temp folder if you do not want to burn it, not sure exactly
Chroma Keyer in Vegas Pro doesn't fully work
By ImJustAKid in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2018, 11:26 -
Authored DVD freezes
By cottage in forum Authoring (DVD)Replies: 7Last Post: 16th Feb 2016, 21:34 -
Cant seem to fully remove interlacing
By killerteengohan in forum RestorationReplies: 3Last Post: 3rd Jan 2016, 02:12 -
Need to convert 60fps footage to 30fps fully-preserved for YouTube
By Hero of Legend in forum Video ConversionReplies: 65Last Post: 12th Feb 2015, 07:02 -
Slimline DVD Case inserts cannot print fully
By etrekma in forum MediaReplies: 3Last Post: 27th Aug 2014, 10:52
