I just started to use OBS Studio to do a full screen capture of video streams. The source is streaming at 3000 something for the older stuff. They have newer stuff at 6000 but I have not tried those yet. I captured at 60 Hz. When I took my captured video into a video editor, I noticed that all the frames were duplicated. So I assume the streaming is at 30 Hz. Sometimes the same frame is duplicated 3,4 or maybe 5 times in a row. I assume this is the streaming not updating. I think I should change the capture rate to 30 Hz to make the files smaller. In this case, is there any advantage to capturing at 60 instead of 30?
Movies are typically shot at 24 fps. Streaming is typically at 24 fps or 30 fps.
If you capture a 24 fps stream at 60 fps the frames will alternate between being repeated 2 times and 3 times.
If you capture a 30 fps stream at 60 fps you will capture every frame twice. And if that 30 fps stream was originally a 24 fps movie one frame out of every 5 is a duplicate in the stream. Those frames will appear four times in your 60 fps cap.
If your capturing animated material, be aware that character animation is typically at 12 fps, panning shots at 24 fps. So you'll see lots more duplicates with cartoons and anime.
The best way to deal with this is to use a smart decimator (one that preferentially discards duplicate frames) after capture to restore the original film frame rate.
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 20:50 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 13:07 -
How can i capture elgato game capture stream to mp4 file with graphedit ?
By Chocolade in forum Capturing and VCRReplies: 1Last Post: 17th Apr 2016, 04:23 -
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 03:45
