Hi,
I have an MKV file (remux from a Bluray) and it's Media info is pasted below. I need to extract the audio lossless with .m4a and/or encode just the audio with quicktime AAC (qaac.exe). I tried ffmpeg to extract but it throws error "Could not find tag for codec dts in stream #0".
Please advise, thanks!!
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Format settings, GOP : M=3, N=12
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 min 50 s
Bit rate mode : Constant
Bit rate : 35.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.703
Stream size : 693 MiB (87%)
Default : Yes
Forced : No
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 4 877 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Delay relative to video : 91 ms
Stream size : 98.9 MiB (12%)
Title : DTS-HD MA 5.1
Language : Hindi
Default : Yes
Forced : No
To convert the DTS to AAC using ffmpeg:
To convert the DTS to AAC using ffmpeg while keeping video and mkv container:Code:ffmpeg -i "input.mkv" -map 0:a:0 "output.m4a"
To convert audio to AAC using qaac:Code:ffmpeg -i "input.mkv" -map 0 -c:v copy -c:a aac "output.mkv"
Code:ffmpeg -i "input.mkv" -map 0:a:0 -f wav - | qaac - -o "output.m4a"
Thanks a lot sneaker
that worked great...
As I need 448k AAC, I ran the below which worked fine:
is there any better way to do OR my command just fine?ffmpeg -i MyVideo.mkv -map 0:a:0 -f wav - |qaac64 -i -c 448k - -o output448.m4a
Thanks again.
Capturing ffmpeg RAW or Lossless Video & Audio
By TubeBar in forum Video Streaming DownloadingReplies: 3Last Post: 24th May 2018, 02:11 -
how can i extract the sound of the original file format with ffmpeg?
By sommers in forum Newbie / General discussionsReplies: 7Last Post: 5th Jun 2017, 12:59 -
Using ffmpeg to extract frames from mts file fails
By Prototype v1.0 in forum Video ConversionReplies: 30Last Post: 1st May 2015, 01:39 -
Saving AAC audio section from mkv file in ffmpeg
By ShadowEdit in forum AudioReplies: 8Last Post: 7th Mar 2015, 16:54 -
extract whatever audio part with ffmpeg
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 31st Oct 2014, 14:31
