I have a video in MKV that starts with this annoying, loud buzzy noise. Is there a way I can remove or reduce the noise volume to a more bearable level? Or I can only get rid of it by cutting the initial seconds with that noise? TIA.
Results 1 to 10 of 10
i'd extract the video and audio from the mkv. edit the audio and then merge them back to mkv.
How can I do that?
I have here on my Windows 10 Pro system:
DVDFab 11.0.2.4 (x64)
HandBrake 1.2.2 (portable)
Inviska MKV Extract 7.0 Portable
mkvtoolnix-64-bit-32.0.0 / MKVExtractGUI2
Format Factory 4.6.0.0 -
mkvextractgui2 save out the audio and video. download audacity(it's a free audio editor). open the audio in audacity, mark out the bad section, reduce the volume there or use a fade in a couple times to reduce the noise. use mkvtoolnix to load the video and audio files and create a new mkv.
If you install the ffmpeg source plugin for Audacity you don't need to demux the audio from the source MVK file. It can import the audio directly from the MKV.
https://manual.audacityteam.org/man/faq_installing_the_ffmpeg_import_export_library.html -
jajabo beat me to it! what the man said is the simplest!
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
I used Inviska MKV Extract 7.0 Portable to extract the English audio, which was an MPEG-2 Advanced Audio Coding file, and the video, which was an H264 file.
When I played the audio alone, there was no such noise. So I took these two files and created a new MP4 using HandBrake 1.2.2 (portable). It was not necessary to edit the audio. Now I have the MP4 playing without that annoying noise.
The problem is solved and now I know why the noise is there if I play the original MKV. It has three audio tracks:
- Video_Audio01.ac3
- Video_Audio02.ac3
- Video_Audio03.aac
The first file on the list, which plays when I start the video, is the one with the noise. It's an original Brazilian Portuguese dub.
Fixing subtitle entries that start after they end?
By bizzybody in forum SubtitleReplies: 8Last Post: 21st Apr 2018, 03:41 -
Playing only the Subtitle Grid from start till end
By IDAN in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jan 2018, 15:53 -
Any way to speed up a whole subtitle file? (identical start, earlier end)
By kilo in forum SubtitleReplies: 2Last Post: 14th Nov 2017, 15:14 -
Trimming start and end off multiple files
By hapsee in forum EditingReplies: 1Last Post: 7th Feb 2016, 08:26 -
Basic NRE for Windows that can re-encode at given start/end frames?
By yetanotherlogin in forum EditingReplies: 4Last Post: 26th Feb 2015, 03:44
