I would appreciate some help on the following questions?
1) How to convert an MKV file to MP4, and viceversa, without converting the video?
2) How to select the video codec when converting an avi file to mp4?
3) Is it possible to convert an avi codec into another one?
The questions about the codecs is because I want to import an avi file into Sony Vegas and the program does not recognize the codec.
I did use Videocoder to convert the avi file into an MP4 file, and I have the same codec error.
The avi codec is mp42 (isom/iso2/avc1/mp41)
I am aware avi, mkv and mp4 are just containers. So I wonder if there's some way to convert the codecs
				Results 1 to 19 of 19
	OK, this time I could import the video part of the avi file, not the audio. Any special trick to do that?
 Both Vegas and ffdshow are 64-bit. I don't know how to enable MP42 in ffdshow. It's there, but I don't see any box to tick and enable it.
 I will look into the Vegas tutorial to see if there's any way to open the video full-screen, so I can see properly what I'm doing.
	Select Start -> All Programs -> ffdshow x64 -> VFW Configuration 64. At the configuration dialog select the Decoder tab near the top left. Just below that highlight Codecs in the list. To the right of that click on the Decoder column next to MP42. Use the pulldown to make it say libavcodec, not disabled.
 [Attachment 48670 - Click to enlarge]
 Also check the Audio Decoder Configuration and make sure the appropriate audio decoder is enabled.
	Of course I did that, but it's completely out of sync.
 I would have to learn how to move the whole audio track to sync it.
 Another thing is how to export it, because the file is 25fps. Going to 30fps would imply a full re-conversion, with frames added and all that.
 So on my test I exported to AVCHD 1440 x 1080 50i, and I got a 25fps video as a result (do not ask my how).
 The format is m2ts. so the file is enormous, x6 the original size, but the movements are much smoother than the original too. Do not ask me how either, but it does.
 What I wanted to add was a light sharpening, which ended up perfect. But all the image looks much better than the original, and I have a trained eye.
 This film is from '48, and was never released in Blu Ray, but does show possibilities on DVDs that also were not.
 I also have a film that had been originally released in DVD, but this time they re-released it in BD. A complete disappointment! The images might have more resolution, but it's much darker and lifeless. Perhaps I can process the BD version with Vegas and get closer to the original look.
	In an NLE that usually as simple as dragging the track left or right in the timeline. Or right clicking on it and selecting something like properties, delay, start time from the context menu.
 https://www.youtube.com/watch?v=LeXUgOUJUus
 I think he said CTRL + U.
	If you already have an MKV with suitable codecs you can remux to MP4 with MKVtoMP4.
 https://www.videohelp.com/software/MkvToMp4
	Create a folder in C: named 'Video'
 Download FFMPEG from here: https://ffmpeg.zeranoe.com/builds/
 Make like a screenshot
 Claudio
  MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43
  FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 08:45
  Convert .TS file with subtitle to MP4 or MKVBy Cazz in forum Video ConversionReplies: 19Last Post: 4th Feb 2017, 17:51
  How do I convert a 20GB MKV file to a smaller x264 MP4?By R.STEED in forum Blu-ray RippingReplies: 11Last Post: 9th Jan 2017, 15:08
  How do I convert/re-encode this huge mp4-file to mkv (h264)?By Packan in forum Video ConversionReplies: 4Last Post: 21st Jun 2015, 15:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
