Hi,
I downloaded an ISO file and tryed to extract the VOB files with DVD Decrypter but this time, the application only recognized the ISO, but didn't gave me any options to work with. IFO, File or ISO: nothing appeared in the right menu columns, it was blank and no way to do anything with that ISO.
The 7zip program can extract from ISO - unless it's encrypted or a fake file
WinRar open it but I need the ISO to work with Decrypter to take off audio files and subtitles I don't need.
I'll try with Shrink -
If it's not an original DVD, it may not be in the proper format for DVD Decrypter to read or extract. If you can extract with 7zip or WinRAR, DVD Decrypter can also read files from a folder, not just ISO.
No. If the ifo's are valid then dvd-decrypter should work (once you have all the files on your HDD in readable form - i.e.via WinRAR)
But that is all I will say since you are downloading, presumably, warez.
If you owned the disk you would not even be mentioning 'iso' or 'downloading' -
How do I open an ISO from DVD Decrypter?
By Vitality in forum DVD RippingReplies: 3Last Post: 20th Oct 2018, 17:25 -
CODECS options in a m3u8 File??
By aj-stream in forum Newbie / General discussionsReplies: 6Last Post: 19th Sep 2018, 09:00 -
Added 1 extra Audio/Subtitle file to a DVD, VIDEO_TS = OK ,ISO=NOT
By DeusExMachinaN7 in forum Authoring (DVD)Replies: 7Last Post: 10th Oct 2016, 03:14 -
DVD drive takes 5-7 sec pauses while backing up to ISO in DVD Decrypter
By guy24s in forum DVD RippingReplies: 1Last Post: 7th Sep 2015, 09:25 -
MTS files to DVD ISO any free options?
By videovic in forum Video ConversionReplies: 22Last Post: 13th Jul 2015, 01:22
