hi, sorry for my bad english,
i read in internet, you can use GPU to help FFMPEG to run faster,
i have this intel HD graphic 4600, and nvidia geforce gtx 750 ti,
can i use it for FFMPEG?
if it can, can it set priority(like priority in task manager) to low or background?,
(i dont want my display lag when browsing)
thanks for reading
Results 1 to 13 of 13
Specify h264_nvenc, hevc_nvenc, h264_qsv, or hevc_qsv as the encoder.
You can always use Windows' Start command to start programs at low priority.
Code:Start /b /low "Window Name" ffmpeg.exe...
Add to the command line after the source input:
Do a web search for command line parameters.Code:-c:v h264_nvenc
something like this
and the result isCode:"c:\ffmpeg.exe" -i "%~1" -c:v h264_nvenc -f segment "%~dp1output\%~n1.%%03d.mp4"
i will try other option then,Code:[h264_nvenc @ 000002935ebf6480] Driver does not support the required nvenc API version. Required: 9.0 Found: 8.1 [h264_nvenc @ 000002935ebf6480] The minimum required Nvidia driver for nvenc is 418.81 or newer Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
thanks for the reply -
You might have to force the GOP size to match the desired segment time. For example, with a 25 fps video set the GOP size to 50 to match the 2 second segment size:
If you get it working, please post the full command line here. It may be useful to others in the future.Code:-g 50
i will try it later. currently, the batch is processing 500mb of a video file, i don't know when it done,
meanwhile i looking for alternative way, making a list without -c:v h264_nvenc(or hevc_nvenc, h264_qsv, hevc_qsv),
and split the result using -c:v h264_nvenc, and i did not make any progress -
adding '-strict_gop 1' might help
users currently on my ignore list: deadrats, Stears555, marcorocchini -
thanks for the reply, i added the '-strict_gop 1', the result is like this
but the result is not precise,Code:"c:\ffmpeg.exe" -i "%~1" -c:v h264_nvenc -g 50 -strict_gop 1 -f segment "%~dp1output\%~n1.%%03d.mp4"
i still prefer using " -c:v h264_nvenc",
i know it very slow (almost 5x slower), but it precise,
thanks for your concern
FFMPEG and new GPU-based YADIF_CUDA deinterlacer
By hydra3333 in forum Video ConversionReplies: 25Last Post: 6th Mar 2019, 12:33 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 16:17 -
To GPU process, or not to GPU process ? 450fps HD -> SD
By hydra3333 in forum Video ConversionReplies: 9Last Post: 28th Nov 2017, 07:01 -
ffmpeg nvidia-gpu-accelerated encoding using NVENC - commandline settings
By hydra3333 in forum Video ConversionReplies: 3Last Post: 7th Sep 2016, 09:11 -
Which GPU is my PC using? I see two
By lingyai in forum Newbie / General discussionsReplies: 7Last Post: 1st Jan 2016, 16:14
, it indeed fast but the segment cut is not precise, i will back to non "-c:v h264_nvenc" then
