I was given a DVD-RW to rip the content off from. It was given to me by an elderly man, who had a lot of original stuff, but was not ever technically savvy. Sadly this is the last disk he has of his stuff. I think he said the disks had stopped working one by one and/or he lost a bunch. It doesn't make sense to me that they would just stop working, without being physically damaged, but the disks are not in bad condition at all.
The last disk he had would play in VLC but not open in explorer. I was able to rip and transcode the last disk he had just fine (so no worries, the job is complete) using MakeMKV. However, when I tried to view the file structure I get an error, "X:\ is not accessible. The disk structure is corrupted and unreadable." I initial thought was that maybe the disk had been transcoded with PAL, but afaik I should still be able to see the contents if that were the case.
I rip a lot of DVD's with MakeMKV, and I have only come across this issue when the disks were just plain not readable, due to actual physical damage. I guess I'm just wondering if anyone has any insight on this, and why it would work to manually load the disk through VLC or MakeMKV, but not by trying to view the file structure. These disks were pretty important to this nice old man, maybe if I dig deeper, then I can save more than just one disk.
Then again, if it turns out to just be some scratch issues (which really doesn't appear to be the case), then I could always resurface them. I just don't see the minor scratches it has, to be causing the issue.
If he "recorded" the disc on a DVD Recorder, that would explain a lot.
I think you may be onto something here.
I think this is going to do the trick. If not, I'm still going to use this tool a lot, so thanks for that. I already gave the disk back, but I'll be going back this week to try a few things.
I also realized that it might be some file system format that Windows doesn't recognize, but we'll see when I get there. I'll post an update if I find anything worthwhile to share. -
Unless it is a strange, no-name brand, odd model device, it will only be using a combination of: ISO9660, UDF 1.2, UDF 2.01, UDF 2.50, or UDF 2.60, with possible Romeo, Joliet, or Mt.Ranier bridge extensions.
With the exception of Romeo & Mt.Ranier, current versions of Windows & Mac & Linux should have no trouble with any of those filesystems. Certainly not ISOBuster.
DVD "fake" 5.1 DTS is actually stereo... how to fix empty channels?
By Sapito in forum AudioReplies: 1Last Post: 3rd Jan 2019, 04:31 -
Portable Hard Drive Suddenly Empty
By Tom Saurus in forum ComputerReplies: 19Last Post: 9th Sep 2018, 01:57 -
Camcorder disc seems empty played on PC
By lizzy84 in forum Newbie / General discussionsReplies: 5Last Post: 24th Nov 2016, 11:07 -
FCPX 10 crashed - project empty?
By lapsang in forum MacReplies: 5Last Post: 20th Dec 2014, 02:14 -
VirtualDub empty codec list
By bigbangnet in forum EditingReplies: 2Last Post: 12th Oct 2014, 12:39
