Results 1 to 9 of 9
  1. Hello!
    I would like to replace the audio of an MP4 video with another aac audio file and split the video.
    I tried to do it with AviDemux but for some reason it keeps crashing. Then, I tried with VirtualDub2 but I get the message that I must choose another input driver.
    What am I missing? Is there some other (free) tool to do this?
    Thanks!
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    AAC? Isn't that Apple? What you're missing is that AAC is proprietary. You need to convert to non-Apple codec.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Once you get the audio straightened out....replace the audio and create a new file....THEN split the new file.
    Don't make the software try to decide whether to wind it's butt or scratch it's watch.
  4. Thanks guys!
    The Mp4 video I have has already an aac sound. And I want to replace it with another one of the same format.
    Ok, let's say that I break the whole process in two steps. Which tool should I use for each process?
    Mar 2008
    With the tools I'm currently aware of, I'd use mkvtooknix to create an mkv with the streams I want,
    then turn it back to an mp4 after it was done. The task shouldn't be this hard
  6. Map the audiostream using ffmpeg
    ffmpeg -i original.mp4 -i new.aac -c copy -map 0:v:0 -map 1:a:0 output.mp4
  7. These two methods will reencode?
    Mar 2008
    The option I mentioned does not; I don't think the ffmpeg method does, but you should try it and see
  9. The ffmpeg method doesn't re-encode either. It keeps the original video stream and simply replaces the audio stream in the mp4 container.
