In 13, I would use CTRL-[ and CTRL-] to jump the cursor to the start and end of the current selection.
In 15, CTRL-[ still jumps to the start,
but CTRL-] also goes to the start, not the end.
Am I doing something wrong ?
How do you skip to the end of the current selection?
				Results 1 to 11 of 11
	I never upgraded beyond 13, but ever since I started with Vegas 4, you can easily customize the key board to perform any operation you want. It sounds like they screwed up one of the shortcuts. Just go to the keyboard shortcut options and change it.
	I already answered that. You might want to ask your questions in the Magix Vegas forum:
 https://www.vegascreativesoftware.info/us/vegas-pro-forum/video/
 Perhaps everything has changed in the latest release, but the first thirteen releases had the setting in the Options menu, just like I already told you.
	Look, I am trying to help you, so that reply is not very appropriate.
 1. You can press F1 to get the help system in Vegas and type "keyboard shortcuts" and find out not only where the option is, but how to use it.
 2. You can go to the Options menu in Vegas and then select "Customize Keyboard." This is the same advice I have posted in this thread twice. This makes a third, and final time. It appears you didn't even make an attempt to click on the Options menu, or you would have seen the option. If I sound annoyed, I am, because I spent the time to help, and then you made no attempt to do something.
 3. You can click on this link and then go to page 557 of the user guide:
 https://images-na.ssl-images-amazon.com/images/I/E1lllY2i6QS.pdf
 It provides complete instructions on how to customize your keyboard.
 I don't know how much more clearly I can provide your answer than what I wrote above, and how much more hand-holding you expect. You now have to actually do some work yourself.
	The OP probably has the basic versions of Vegas Movie Studio 13 and 15. No "Customize Keyboard" in Options menu of any of my MSP versions (10 to 16). (The last Movie Studio (Platinum) version to include "Customize Toolbar" was v.12.) A user with the same username asked this and got a reply confirming his KB Shortcut issue in VMS 15 on the Movie Studio section in the Magix Vegas forum. Last edited by vkmast; 14th Apr 2019 at 06:52.
	The original post said "Vegas" which I took to mean Vegas Pro. Movie Studio, at least in the Vegas forums, is usually referred to a Movie Studio, not Vegas. I therefore didn't realize he had that version, and certainly didn't know Magix had removed the customization.
 Thanks for the clarification.
	I very much agree that the posters should clearly state the version they are using. This is still a problem on the Magix Vegas forum as well despite it being mentioned in one of the main stickied FAQs (https://www.vegascreativesoftware.info/us/forum/important-information-required-to-help-you--110457/) and Movie Studio having its own section.
 Note that in Magix Vegas Pro versions there are still Options to Customize Toolbar, Timeline Toolbar and Keyboard. No Movie Studio version currently has the Option to Customize Toolbar, which was in some of the earlier versions.
	Apologies to JohnMeyer, as you've been a big help in general.
 . I updated my profile to indicate my software version.
	In other news, I verified that CTRL-] never worked in v13 either, so I must be dreaming.
 I only ever used CTRL-[ to go to the start of a selection
  WHY PRESSING CTRL-ALT-CANC Windows 10 go on fullscreen?!?By marcorocchini in forum Newbie / General discussionsReplies: 14Last Post: 14th Feb 2019, 14:18
  Current PAL/NTSC DVD Conversion Guide? Current Guides are outdatedBy isj209h23h in forum User guidesReplies: 3Last Post: 20th Jul 2018, 22:53
  Chroma Keyer in Vegas Pro doesn't fully workBy ImJustAKid in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2018, 12:26
  How can I make Sony Vegas work with a YUY2 interlaced video?By enzeru in forum EditingReplies: 6Last Post: 16th Jun 2017, 17:20
  Vegas Movie Studio 10 won't start -- would a newer version likely work?By shun in forum EditingReplies: 3Last Post: 4th Sep 2015, 11:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
