I've got an nginx rtmp setup on the cloud, which I use as a "distributor" that takes a single rtmp input and splits it out to multiple rtmps such as Facebook and Youtube. There are ffmpeg processes that take the input rtmp and then encode it according to various requirements such as scaling down to 720p for Facebook, and outputing to the Facebook server.
I push to this server from Wirecast/OBS on a PC. I'm trying to setup some kind of redundancy for the input, so there are effectively two PCs. If one PC goes down, I start pushing to the server from the other PC.
Initially, I had setup NGINX so that in case the stream from one PC goes down, the rtmp server closes the rtmp connection from the PC. This causes the ffmpeg process taking the input to shut down too. Sometimes this leads to Facebook (which was being fed by that ffmpeg process), thinking the stream has ended and closing the stream. To prevent this, I configured NGINX so that the rtmp connection stays open for a while, in which I time I get the second PC to push a stream. The ffmpeg process does not break in this case. But I've noticed that in case the two PCs are streaming on different x264 profiles, let's say one is on High and the other on Baseline or Main, the ffmpeg process starts to throw a lot of errors/warnings when it starts using the second PC stream. Below is a sample of the errors:
So long as I'm on OBS/Wirecast, I have control over the profile, so I'm able to avoid these errors. But the problem arises when one of the PCs is replaced with a hardware encoder such as the LiveU Solo or even if I use Wirecast with MainConcept as encoder instead of x264.Code:[NULL @ 0x56330347c380] illegal reordering_of_pic_nums_idc 22 (and other numbers) [NULL @ 0x56330347c380] reference count 1 overflow [NULL @ 0x56330347c380] illegal memory management control operation 32 (and sometimes 16)
Any ideas how I can solve this problem. Currently, I'm encoding one of the inputs with libx264 to ensure that the profile and level match that of the other input. But that's pretty CPU intensive for a 1080p stream and I sometimes have multiple 1080p streams happening. Anyway to avoid this encode?
Results 1 to 1 of 1
Can I stream from an rtmp encoder TO a VLC player or to ffmpeg w/o server?
By zopiro in forum Video Streaming DownloadingReplies: 3Last Post: 25th May 2016, 09:31 -
(Willing to pay)ffmpeg Need help downloading live stream ffmpeg and rtmp
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2016, 16:54 -
How can I stream h264 files with FFmpeg over rtmp without reencoding?
By Ninelpienel in forum Video Streaming DownloadingReplies: 4Last Post: 11th Mar 2016, 12:47 -
How to select profiles in h.265 in ffmpeg?
By praveenkk in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2015, 03:01 -
ffmpeg rtmp restream to fms or wowza
By dannik in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2014, 08:27
