Someone, somewhere in the subtitling community is using some really screwed up software that splits all multi-line entries so every line is its own entry. Even worse, when it splits them it duplicates the timestamp. Could be converting, poorly, from closed captions.
Some players will do weird things with those subtitles. PotPlayer inverts the order of them, displaying the earlier duplicate entry on the bottom then stacks the later ones above it.
Oddly, MKVToolnix GUI's multiplexer *does not* throw any errors on *duplicate* times, only on *overlapping* ones or ones where the end time is earlier than the start time.
Is there any SRT cleanup or fixer or editor software that can fix this?
Turn this
1
00:00:07,120 --> 00:00:08,030
- Previously,
2
00:00:07,210 --> 00:00:08,030
on "The Magicians"...
3
00:00:09,090 --> 00:00:12,030
- A huge reservoir of magic
4
hidden underneath the castle?
5
00:00:12,050 --> 00:00:15,000
- Where does it lead?
6
To Roderick's secret chamber?
7
00:00:15,000 --> 00:00:16,050
- The Binder had a theory.
8
00:00:16,070 --> 00:00:19,280
When a being of great power
9
such as a God is killed,
Into this. Note that entry 7 is supposed to be one line, becomes the new entry 5
1
- Previously,
3
4
5
6
Subtitle Edit -> Tools -> Merge lines with same time code ..
[Attachment 48634 - Click to enlarge]
Subtitle Edit Generating Blank srt with timestamps
By aoife in forum SubtitleReplies: 1Last Post: 6th Nov 2018, 12:37 -
Crashes at seemingly random subtitle entries
By owengall in forum MacReplies: 0Last Post: 27th May 2018, 01:05 -
Fixing subtitle entries that start after they end?
By bizzybody in forum SubtitleReplies: 8Last Post: 21st Apr 2018, 04:41 -
Help please, unable to merge srt to avi using AVIDEMUX
By pwangdel in forum EditingReplies: 9Last Post: 16th Jun 2016, 04:08 -
Combine/merge two subrip srt of different languages into one
By leesing2k in forum SubtitleReplies: 8Last Post: 18th Apr 2016, 15:08
