It's time. What's the smoothest route? Will all the 32-bit filters still work or will I need to use two Avisynths?
The smoothest route is to do a brand new separate install of whatever 64-bit AVISynth front-end you choose. I use meGUI.
32-bit filters don't work in 64-bit unless you use mp_pipeline or other like methods. But then that kind of defeats the purpose. Almost all of the most useful filters (at least in my opinion) have been ported to 64-bit, but sometimes it can take a bit of hunting around on avisynth.nl and doom9.org for everything. Keep your 32-bit installation just in case. -
So if I do the brand new x64 install, how do I switch between versions? Like, if I have an AVS script I'm about to open with virtualdub, how do I choose which Avisynth will be the middleman?
Over here I use the "Universal Avisynth Installer", you can switch between 7 different versions of Avisynth, including x64 versions.
Btw, I never saw any significant improvement to justify the use of x64 versions.
Avisynth 64 Bit + LSMASHVideo 64 Bit
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 12th Dec 2018, 04:49 -
AFS and avisynth plus 64 bit slow speed
By qo4on in forum Newbie / General discussionsReplies: 21Last Post: 21st Jan 2018, 14:29 -
from 4:3 to 16:9, in crop/resize mode and avisynth 64 bit?
By marcorocchini in forum Newbie / General discussionsReplies: 27Last Post: 25th Oct 2017, 22:45 -
How to Convert 10-bit to 8-bit with AviSynth?
By MrBiggles in forum Video ConversionReplies: 4Last Post: 6th May 2015, 05:38 -
What 10-bit colorspace can I use with avisynth?
By -Habanero- in forum Newbie / General discussionsReplies: 20Last Post: 26th Apr 2015, 00:12
