i need a avi file joining tool, i got virtual dub and it says it is a avi joiner but i don't know how to do it, so if u know how please message me back and describe how to use it, or if u know a good one and wehre i can get it message me thanks for ur help.
Results 1 to 13 of 13
The Wiz
You could try reading the help file
File/Open Video File then File/Append AVI Segment -
thanks smart allic but that doesn't work because it has to be from the same movie the file so i need one that will put two seperate ones togethor please reply thanks
The Wiz -
There are probably simpler ways but here is what I've done. I've taped shows off TV, then fed that to my capture card creating multiple AVI files (cutting out the commercials
). Then I use TMPGEnc to convert each AVI file into MPG files. Then again using TMPGEnc I simply join all the separate files into one MPG file (VCD format). This can be done whether the AVI files are from one show or multiple.
yeah i know how that works, but i want to know how to just join AVI FILES NOT MPG PLEASE HELP
The Wiz -
err TMPG works with AVI files too so why cant you use it to join these too?
You said you know how to join them using tmpg yes/no let me know i can help on that one. -
how does tmpgenc merge avi's? from what I found it can only merge mpg's...... for avi merging try downloading ulead video 6, its a 30 day trial demo,,,,, works good for me.........
thanks for the responses i know that you are able to join mpg files with tnmpg but not sure on the avi files so if u can just tell me how i can do it please and where can i find this other program for the 30 day trial?
thanksThe Wiz -
have you looked at the how to edit guides on the left?
this one here shows you step by step how to join avis with VDub:
http://www.vcdhelp.com/virtualdubedit.htm
it is just as easy as it looks -
You are welcome to try Clip! - my own AVI editor. It is a quick way of cutting and joining AVI files.
Download it from http://www.billh.demon.co.uk
following the video editing link - its free!
Like Virtual Dub, Clip! will only join files that are of the same format. If you need to join two files of differing formats, then you will need to re-encode one of them first to be the same as the other. You should be able to do the re-encoding with Virtual Dub.
Once all files are the same format, then either Clip! or Virtual Dub should be able to assemble them for you.
The critical parameters include frame size, codecs, audio parameters.
If this doesn't work, then you probably need a full video editor, like VideoWave, MediaStudio, Premiere etc. This will automatically re-encode the video for you behind the scenes! -
thanks for the message about virtual dub but if u would read i said that it wouldn't work because it says it is not from the same video... but i guess u read that....... thanks for the link to the other page with the other program i'm just gunna try that one
The Wiz -
There is a help file with the program, which explains the features of the program, and how to use it.
Basically - you need to do the following:
In the Files panel, click on Add.
Browse to one of your files and select 'Open'.
Clip! should open the file and display it in the preview window.
You then need to create a clip from the file, as follows:
Set the In and Out points by dragging the markers on the play bar just above the preview window.
(Note: When you load a file by default the whole file is selected)
Click on the Add button in the Clips panel.
Add your second file by clicking on the Add button in the files panel.
Select and Add a clip in the same way as you did for the first clip.
Click on the Produce button and wait.
Thats it!
If you get a 'Files incompatible' message when you add the second file, then you will need to Virtual Dub or something elese to convert the second file to the same format.
Clip! allows you to join an unlimited number of files and clips. If things get very complicated, then it is a good idea to save your work as a clip project from time to time in case your computer crashes!
Best of luck.
VisiBill.
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
joining avi
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2010, 07:13 -
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 21:29 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 18:07
