Hello,
I have an issue with DV footage and am not sure how to proceed.
The problem concerns VHS-C tapes that I recorded directly onto my MiniDV camera around 15 years ago. At the time I just used component input, but it still looks much better than the actual VHS-C footage at this point in time, so I'd like to work with it.
Unfortunately, during fast movements (mostly pans) the video glitches/destabilizes for a moment. It's even visible on the camera display (but as a sidenote: I transferred the tapes to dv1-files using dvgrab and the issue was retained).
Any idea what could cause this? Both cameras are PAL, so it's probably not a framerate difference. Maybe an internal image stabilizer on the MiniDV camera (though I wouldn't have thought that this would be turned on with external video input)?
If I can recover most of the original VHS-C tapes, I'd consider the idea of using a few frames from them during affected sequences, but that might be a gigantic chore.
Capturing the original MiniDV cassettes to your computer will provide a superior result. What you are doing now is Digital►Analog►Analog►Digital when it could be just Digital►Digital.
Please post a sample of the glitch. -
I captured them via Firewire and dvgrab (the standard Linux program). No analogue conversion in-between. So it really must have happened while transferring the VHS-C tapes to MiniDV.
I'll get to it later in the day, thanks for taking a look!Please post a sample of the glitch. -
Yes, that would be better (although the few tapes I could find look considerably worse now than the dv recordings from 15 years ago). Unfortunately, most of them seem to be lost and my budget can't justify high-end equipment or a professional service. My only other means would be a subpar VCR and an ancient DVD/HDD-recorder.
I second that. Capturing the original VHS-C tapes will give you better quality, Even though DV smoothed out some noise but that doesn't mean DV tapes are better than the original source. Good luck.
I suspect the problem is on the tape. Camera motion while shooting caused the helical scan drum speed to vary. So the sync timing is off, causing problems during playback/capture. A good time base corrector, like an old Panasonic DVD recorder, may be able to fix it.
VHS captures are washed out.
By Grandpa2390 in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2018, 21:43 -
Playback issues from older camcorder
By CuriousJane in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 25th Jan 2018, 19:23 -
Frame drops & a-sync issues from MiniDV to HD60s
By Aerroblade in forum Capturing and VCRReplies: 17Last Post: 15th Jun 2016, 12:49 -
Stuttering DVD on fast movement
By akkers in forum Authoring (DVD)Replies: 9Last Post: 4th Apr 2016, 13:04 -
AmaRecTV Audio Sync Issues On Long Captures??
By BlockABoots in forum Capturing and VCRReplies: 10Last Post: 13th Feb 2016, 15:49
