I'm using twixtor v6 for AE 2014 to upscale a movie to 60fps, and I ran into an issue. Twixtor tries to interpolate the frames in between the clips of the movie (which aren't separated, its one mp4 file), which gives a weird morphing look (I can post an example if this isn't a great description). Is there a way to fix this by setting a motion threshold? This would be something to the effect of "When motion is more than X amount, opacity = 0%". I imagine this would only work with twixtor (as vanilla AE probably doesn't have a way to detect the amount of motion).
The reason I want to do this is so that I can avoid having to separate each individual clip in the movie. Does anyone have an idea of how to fix this?
Thanks!
You're being unclear (to me, anyway). If it's a single video file, then there aren't any 'clips'. Do you mean to say it's interpolating at scene changes?
Also, to 'upscale' means to increase the resolution. But why increase the framerate of a 24fps movie? Perhaps to make it play more smoothly?
FPS Issue on MakeMKV DVD rip, help?
By Vitality in forum DVD RippingReplies: 13Last Post: 24th Oct 2018, 01:55 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 11:47 -
convert 30 fps time lapse video to 60 fps to speed up and keep all frames
By acem77 in forum Video ConversionReplies: 12Last Post: 19th Jan 2016, 20:01 -
Playback Issue: Source Video with Inconsistent FPS
By ctr2yellowbird in forum Newbie / General discussionsReplies: 17Last Post: 21st Dec 2015, 20:45 -
frame rate reduction of 29.970 fps to 23.976 fps in megui
By yohanfed in forum Video ConversionReplies: 2Last Post: 28th Jun 2014, 19:15
