Hi,
I have yet to find any solutions on the topic, as I guess most people simply aren't doing this, so iif you have any suggestions, please let me know your thoughts.
Running this off my Dell Server to South Central Cable TV channel 24/7 and there is a lot of flicker and hard to explain almost slow refreshing of video in various parts between frames? Footage is 1080p (CBR 15mbs) scaling to 720p (CBR see FFMPEG)
$ ffmpeg
-re
-i playlist1.txt
-s 1280x720
-b:v 12000k
-b:a 384k
-bufsize 24000k
-maxrate 12384k
-f mpegts "udp://225.254.1.XXX:XXX4?pkt_size=188&buffer_size=65535"
Also instead of converting the .mp4 from Davinci output through FFMPEG to MPEG2 TS, I am batching them to MPEG2.TS with XMedia Recode. Tried a bunch of settings, but that doesn't help. And of course the video looks great on local PC play. Obviously its on the transport end, and probably something that could be improved I am guessing on my FFMPEG command structure?
Ask any additional questions as needed, standing by...
Thanks!
Try adding the following:
As the resolution is 1280x720, can we assume the original material is progressive scan?Code:-vcodec mpeg2video -r 59.94 -pix_fmt yuv420p -acodec mp2 -vf scale=out_color_matrix=bt709:out_range=limited -color_primaries bt709 -color_trc bt709 -colorspace bt709 -muxrate 6.0M
Find out what other services might be running on this channel, i.e. subchannels.
-muxrate will nail down your bandwidth to a constant 6.0 Mbps.
Are you using MediaInfo to examine your files?
https://mediaarea.net/en/MediaInfo
Good luck!Last edited by chris319; 15th Jun 2019 at 18:58.
I think many people have simply given up on cable TV and therefore are not looking for any solutions to this issue. Personally, I gave up cable TV for a long time because it is not profitable. I had to pay a lot of money for it and it wasn't worth it. Fortunately I found at https://yourmoneygeek.com alternatives to cable TV and switched to streaming. Now I pay several times less money and can watch what I want without advertising
How to see a 5.1 file's channel layout? + Channel layout error with ffmpeg
By HoraceMcMahon in forum AudioReplies: 70Last Post: 21st Sep 2025, 11:18 -
ffmpeg 1080i50 to 720p
By illus in forum Video ConversionReplies: 14Last Post: 3rd Nov 2016, 10:02 -
Options for playing local PC content on TV via ethernet cable
By punchball in forum Media Center PC / MediaCentersReplies: 9Last Post: 15th Aug 2016, 12:17 -
Is it possible to 'offset' a channel (Y,U,V) of a component cable?
By Szabo2 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th Feb 2015, 11:24 -
How you record 20 analog cable tv channel?
By st0rm911 in forum Media Center PC / MediaCentersReplies: 11Last Post: 17th Apr 2014, 19:32
