  1. I extracted the avisynht.zip file to the same folder as FlaskMmpeg and then copyed the avisynht.dll file to the windows\system folder and double-clicked the register file in the flaskmpeg folder; the register was succefull appeard.
    But when i openn the FlasKmpeg and go to options->select output format, the option avisynht doesnt appear. Why?
    Please help me, :(
    thank you
  2. I don't know you can use AVIsynth in the way you described. AVIsynth is a script language mainly used as a frameserver. It doesn't have a GUI. You have to write script by yourself. Please read some guides on AVIsynth, because it's a VERY useful tool that every video enthusiast should be familiar with.
    Feb 2001
    Berlin, Germany
    In order to use Avisynth to frameserve from FlasK you need the Avisynth premier plugin. http://www.videotools.net
