Quick question on bitrate settings in Handbrake...
Which setting under the Video tab of Handbrake puts out a variable bitrate? Constant Quality or Average bitrate?
I do understand that Average Bitrate is still somewhat variable since Handbrake tries to keep it around that bitrate. But I guess I'm trying to figure out which one is the most variable - if that makes sense.
Simple answer, they are both variable. However, if I remember correctly, CQ is by definition more variable, it's all source dependent....
Average Bitrate without 2-Pass Encoding is the least variable in terms of bitrate. It's also the worst quality per bitrate. Average Bitrate with 2-Pass encoding is very close to the same bitrate distribution as Constant Quality, and the same quality when the file sizes match.
With Constant Quality encoding you know what the quality will be but you don't know how big a file you will get. With Average Bitrate encoding you know what the file size will be but you don't know what the quality.
Handbrake GOP setting
By jseo13579 in forum EditingReplies: 13Last Post: 27th Sep 2020, 19:11 -
Handbrake encoding at Variable FPS when Constant is chosen
By ManiKz in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2019, 15:16 -
Should I start over again? (Video=Variable) (Audio=Variable Bitrate)
By strawberryshortcake in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2018, 07:16 -
HandBrake giving me variable frame rate when I asked for constant
By Bruce Wayne in forum Video ConversionReplies: 4Last Post: 18th Apr 2016, 14:07 -
Handbrake Newb: Same as Source + Variable Frame Rate
By EmptyMorale in forum Video ConversionReplies: 5Last Post: 30th Dec 2015, 09:38
