    Oct 2015
    Dublin
    Hello!
    Every time I turn the PC on, it appears in the browser searcher the site
    newsgmae.pro/page.html
    What can I do to end with this?
    Thanks for your help.
  2. If you're running Windows then try the free MalwareBytes as it sounds like you've picked up some ad-ware.
    Oct 2015
    Dublin
    I executed MalwareBytes and after the reboot
    it doesn't repeat the process.
    Thank you TimA-C.
  4. Glad it helped. When the trial period runs out you can change the license to the free one. You won't get permanent protection or automated scans any more - you have to run the scans manually - but it's still a useful tool to have if you're running a PC connected to the internet. Also, I think there's a setting you can turn on to get it to look for Rootkits - why it's off by default . . . ?
