My gamecapture device allows me to capture in either M2TS or MP4. However, MP4 takes some time to process videos while M2TS takes only one second. So is that mean MP4 has better quality than M2TS? Does capturing in different file format have difference in picture display?
No. Your device captures as M2TS. If you elect to use MP4 it first captures as M2TS then remuxes to MP4. That extra step takes a while -- depending on the size of the cap and the speed of your drive.
I guess the remuxing does not re-encode the video part ? it only re arranges the audio and video tracks in the type of file ? will one or the other have a differrent workload on the processing in the player/computer ?
I know the M2TS file format is also used in recording video camera's.... -
Convert 5 individual 1080i m2ts with Dolby AC3 to MP4 1080p 50fps
By bloodhand in forum Video ConversionReplies: 61Last Post: 11th Feb 2017, 13:16 -
Problem converting .m2ts to mp4 h265
By ThePi7on in forum Blu-ray RippingReplies: 14Last Post: 7th Jan 2017, 03:54 -
Requesting Software Recommendation - m2ts ( 1080/60psf ) to mp4 ?
By NewTwoVideo in forum Video ConversionReplies: 13Last Post: 6th Feb 2016, 14:56 -
Loading an MP4, MTS, or M2TS in Avisynth
By SameSelf in forum Video ConversionReplies: 2Last Post: 15th Jan 2016, 09:41 -
AVCHD / M2TS / BDAV to MP4 without re-encoding
By Lossless Lion in forum Video ConversionReplies: 4Last Post: 23rd May 2014, 11:16
