Dear,
I've been using ffmpeg long time ago to download from shahid.net, The changed it several times but I always get it. I didn't do any downloads in the last year and I can see they changed it one another time.
They implemented HLS and AES encryption, which I did before with another website. But now they have some weird m3u8 data there, there's no direct links to the ts streams instead we're talking about a manifest file which leads to video fragments.
The manifest file will have the AES decryption key with it and I got the key, but the manifest list as I said doesn't have direct links to individual .ts streams. What I see instead is
It's just a part of the sequence (which has over 1700 sequence/fragments).Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-ALLOW-CACHE:NO #EXT-X-MEDIA-SEQUENCE:0 #EXT-X-TARGETDURATION:6 #EXT-X-KEY:METHOD=AES-128,URI="https://shahidkey-a.akamaihd.net/?kid=a2cb40a4-6af0-4631-a13c-4a34e540f93d",IV=0X6C20557FBBCFA150C2356FF5524791BF #EXT-X-PROGRAM-DATE-TIME:1970-01-01T00:00:00Z #EXTINF:6.000000,no-desc Fragments(video=0,format=m3u8-aapl-v3,audiotrack=aac_UND_2_32) #EXTINF:6.000000,no-desc Fragments(video=60000000,format=m3u8-aapl-v3,audiotrack=aac_UND_2_32) #EXTINF:6.000000,no-desc Fragments(video=120000000,format=m3u8-aapl-v3,audiotrack=aac_UND_2_32) #EXTINF:6.000000,no-desc Fragments(video=180000000,format=m3u8-aapl-v3,audiotrack=aac_UND_2_32) ... ... ... etc...
I can download individual fragments from the browser inspect/developer tools. They're just binary, The encrypted HLS stream
this is one of them
https://shahid04-l3.shahid.net/65b60600-0224-4251-a0c9-abb7559a893e/6985408_6100036960...k=aac_UND_2_32)
I created an m3u8 file with the decryption key inside and the whole list of these Fragments files, ffmpeg couldn't parse it and for each fragment it showed me the same single error "Failed to open segment of playlist 0"
This is the command I tried
Code:ffmpeg -i f1.m3u8 -c copy -bsf:a aac_adtstoasc -hls_key_info_file "https://shahidkey-a.akamaihd.net/?kid=a2cb40a4-6af0-4631-a13c-4a34e540f93d" output.mp4
Try v4 of hls with streamlink:
Code:streamlink "hlsvariant://https://shahid04-l3.shahid.net/65b60600-0224-4251-a0c9-abb7559a893e/6985408_6100036960_Formula1Grand.ism/manifest(format=m3u8-aapl-v4).m3u8" best -o output.ts
Thanks bro, it's working albeit with few issues.
I'm in macOS, so I started with a Windows VM, it worked perfectly till the internet disconnected and the file was corrupted. While it was downloading, I tried installing it in macOS and it wasn't something direct as there's no direct way. But I managed to install it, I installed and started to download again everything went smooth without interruption.. after finishing I discovered the file was without audio (no audio stream), so I'm again back in the Win VM downloading it again
Hopefully this time it will work normally. -
Thanks bro, sadly I'll need to compile this as I can't see any compiled or executables there.. I never did this before so currently I'm using the above streamlink method which seems to be similar.
ffmpeg will also work with v1 or v4 hls, but since this master m3u8 is hls-multi (separate video/audio), you might have to specify the child m3u8 inputs separately for the video and audio to ffmpeg, and carefully mux them to insure video/audio sync.
Help downloading AES-encrypted HLS video stream
By Woodswolf in forum Video Streaming DownloadingReplies: 26Last Post: 25th May 2019, 14:20 -
Help me with AES encrypted HLS downloading ?
By shraman in forum Video Streaming DownloadingReplies: 0Last Post: 30th Jul 2018, 06:54 -
By vidder in forum Video Streaming DownloadingReplies: 3Last Post: 4th Jul 2018, 17:24 -
How to save AES encrypted HLS streams?
By tgbripper in forum Video Streaming DownloadingReplies: 1Last Post: 27th Nov 2014, 12:57 -
Downloading HLS with AES encryption ??
By graphics in forum Video Streaming DownloadingReplies: 0Last Post: 14th Jun 2014, 16:25
