Hello everyone! I've been transferring mine and my parents home movies from VHS, VHS-C, 8mm, Digital8, and mini-DV. I'm working my way up in time so I've started with the oldest VHS tapes and 8mm so far.
I use a Mac. My setup is VCR -> Sony Camcorder as passthrough with FireWire out -> computer (or straight from camera to computer for 8mm)
I've been experimenting with different capture methods and I found all have their pros and cons. I tried Vidi, iMovie HD (old version I was able to find and install to capture analog footage since new iMovie needs timecode), Trial of LifeFlix, and QuickTime Player.
(I had some audio sync issues during conversion to mp4 which led me to experiment with different capture software to see if issue was in the dv file or the conversion.)
Anyway!
The last method I tried was Quicktime on the maximum quality setting, which captures in ProRes 422. (The "high" setting apparently captures and encodes directly to H.264 which I don't want, and those are the only 2 settings.)
I was able to overcome my previous sync issues by adding a few steps while converting the dv files (involving demuxing files and encoding A/V separately, then putting back together using ffmpeg.. kind of a process), but capturing to ProRes with Quicktime allowed me to simply capture and convert using handbrake with no sync issues.
Now my question is - are there any DRAWBACKS to capturing in ProRes 422 with Quicktime (as a .mov file) vs capturing to DV, using Vidi, iMovie, etc.? (Other than file size, which is about 20 GB per hour vs 14 GB per hour for dv)
I've been doing a lot of reading and lots of people say ProRes is superior because of the 4.2.2 vs 4.1.1 but also possibly overkill for Analog conversion - but if it solves my audio sync issues, am I creating any other problems? I've read ProRes converts interlaced footage to Progressive on the fly, and not sure if that's bad.. and I also have read that my Sony Camcorder is actually in "DV format" and that DV transfer is basically copying the footage out of the camera into the same format. But then other people say DV is not lossless and also not the ideal format for a few reasons, so I have no idea.
Obviously these are home movies and don't need to be Hollywood quality films - all of my final files no matter which way I use look good enough and are more than passable for my needs. I just have over 50 tapes to do still and I'd like to settle on the best way to do this before I continue and then realize I should have done it another way, for unforeseen issues with incompatibility, conversion, or anything else.
PS. I am archiving the DV / ProRes files on an external hard drive for storage, and using the encoded mp4 on a smaller external portable hard drive for use in Smart TVs and so on.
Results 1 to 30 of 318
On a side note, does anyone know why the Quicktime ProRes capture would be ever so slightly sped up compared to the DV capture of the same footage? Over an hour tape, the ProRes version is about a minute shorter, give or take, and if I play the files simultaneously in sync, the DV captured footage starts to fall behind within a minute.
the best quality that can be achieved from DV tapes is to copy the exact same information from the tape to the computer. DVavi -> DVavi over firewire. transferring the tape to the computer in any other format is going to involve re-encoding it. and if it wasn't DVavi to begin with like a vhs tape then there are 2 re-encodes in the path.
Capturing analog to lossy codecs loses 560% of the original color resolution, thriows away some original data thru lossy compression, requires yet another lossy stage of compression when you make your final output formats, blows out highlights and offers no control over invalid signal levels, and forever embeds tape noise and other analog defects as digital artifacts that don't exist inn the originals.
After all that's been posted about these destructive lossy methods for years and years and years and thousands and thousands and thousands of posts, people do it anyway. It's as amazing as it is depressing.
If you need any help cleaning up the artifacts and other damage, just ask.- My sister Ann's brother -
There is no reason to convert DV or Digital8 to ProRes 422. You cannot create color resolution where none exists in the first place. You are simply adding another compression step which will degrade image quality, however slightly. ProRes is fine for the other analog formats.
ProRes stores video as progressive frames but does not deinterlace. The fields can still be deinterlaced in a separate operation.I've read ProRes converts interlaced footage to Progressive on the fly -
Thanks guys. @LMotlow, I hear you - but many people, such as myself, are doing this to preserve memories, and ultimately are happy with having old VHS tapes in any watchable format, even with some color loss and digital artifacts. Even with those losses, I'm thankful I am doing this now, with the equipment I have in my possession, and that I am able to see my grandparents on the farm in Italy in the 1960s and my Dad as a kid (those were converted from reels to VHS at some point and some of those tapes are Green but we're still just thankful to have them) and everything that came after that. Basically it's either DV or ProRes files for me, or have the tapes rot in the basement never to be seen again. If I don't tackle this now, that's what I'm afraid will happen, and that's why so many people are probably ok with doing it this way
What is your recommended solution for what I'm trying to accomplish? -
@JVRaines, the only reason I was considering it was to avoid the mysterious audio sync issues I was facing with the dv capture converting to mp4, which worked. My intention was not to increase the quality, and my fear was that by fixing the audio problem, I might be creating another problem, like as you mentioned, degrading image quality and at the expense of larger files too. For my analog formats, I am still using an old Sony camcorder as a way to convert the signal to digital to get it into my computer, and so I assume that my analog signal is, in this case, actually dv before it gets to the computer, and therefore ProRes is also not good for my analog tapes. I don't know enough about it by I guess there is some way to capture analog signal to ProRes? That is neither here nor there - I am looking to preferably use what I have and hopefully I can chip away at this project for the next few months! Thank you.
Yes, the Sony is encoding to DV before sending over FireWire. DV is a lossy intraframe codec with rather low color resolution. If these tapes are important, it's better to save the converted data stream to a lossless format such as HuffYUV. In this scenario, use a USB analog-digital video converter, generally under $50.
@JvRaines, I thought those USB capture devices all captured and encoded in one step using H.264 and compressing audio. Is that not right? I’m not familiar with HuffyUV and a quick search shows it’s for Windows and I’m using a Mac, can I still use it? If you know of a device like you’re referring to that works on a Mac, links welcome... thank you!
Some USB converters come with software that saves h.264, but nearly all can be used in uncompressed mode with proper drivers. (It's easier to do in Windows than in MacOS.)
I know the Elgato and Startech USB devices work with MacOS — they are a bit pricey. If you find a capture app that's based on FFmpeg, it will have HuffYUV codec. You'll need to search around a bit to see what's available; you have to get out of the Quicktime walled garden. -
Depending upon the brand, they capture, & convert using choice of system-supplied codecs, or using subset of hardware-assisted codecs, or using proprietary codecs.
IMO, it is better to have the former if you have a beefy enough system, as that gives you the most options. Next is the hardware-assisted, which is mainly only handy if your system is underpowered. Least desirable is the last, but one sometimes is stuck with certain purchases due to budget, circumstances.
Note, in nearly all cases your options are a good deal more limited if you are using a Mac. For example: with current Macs there are only a few allowed capture/storage codecs...DV (for legacy SD DV material), ProRes (for anything high quality to start with or needing to transcode & maintain reasonably high quality), and AVC/h264 or HEVC/h265 for everything else. If capturing from within iMovie you might have a few other options (AIC), or if capping within FCX you have a few more. And if you have Premiere, or Avid MediaComposer, you also have access to their preferred or proprietary codecs that aren't based on Quicktime or AVFoundation system APIs. Some are better than others. Older Quicktime (and FCP, etc) had lots of options, but those are dying or dead options now.
If you have a decent budget, I'd suggest getting an Aja or Blackmagic device/card, as those are high quality & known to work well with Macs. And...you get what you pay for, so GIGO.
I'd also suggest: if your material is originally on tape as DV (same goes for Digital8 which is DV under the hood), transfer via firewire to computer, retaining as DV, edit as DV, save master as DV. Then & only then do you create a converted copy for regular playback use (h264, etc).
If you material is anything else, you are better served (for preservation purposes) capping as high a quality as possible (ProRes or better, on a Mac), keeping it that way throughout, and then also converting at the end to h264, etc.
The previous guys' suggestions are overall good, and well-intentioned, but fail to fully take into account the peculiarities of Macs.
ScottLast edited by Cornucopia; 2nd Apr 2019 at 02:46.
Check out OBS Studio. It's based on FFmpeg and may provide HuffYUV under Mac OS.
True - if OBS can hook into the capture drivers, it should allow for other options. Though in my experience, most Mac products rely on QT/AVFoundation so they don't have to start from scratch.
Scott -
Thank you for all your suggestions. My next steps are:
1. Look into OBS (I can already see I am one MacOS version behind their minimum requirements but I have a mac laptop on current OS that could probably do the capture, but I'd worry about doing the conversion to mpg on a laptop). I haven't updated my main Mac because I have other programs I need that don't run on newer OS. :/ Too bad - this looks like it could have been a winner otherwise, but will still check it out.
2. Look into Elgato and Startech capture devices (I've heard Elgato a few times and with mixed reviews but have not looked into Startech)
3. Look into AJA and Blackmagic - I would be willing to spend some money (within reason) to do this right and headache-free at this point. I've heard Blackmagic mentioned a few times but I've never heard of AJA. Will do a little research and probably end up with one of these solutions.
Using an outside capture device opens up a whole new can of worms for me so if anyone out there has already done the research on any of the above devices, I'd love to hear your input.
I also have to double check what outputs my VCR has. Are regular AV cables sufficient with these capture devices (with regards to the quality we're chasing) or am I looking for S Video? -
FCPX, Avid and Premiere Pro will not recognize a lot of the cheap USB capture cards and even a lot of the PCIE capture cards.If capturing from within iMovie you might have a few other options (AIC), or if capping within FCX you have a few more. And if you have Premiere, or Avid MediaComposer, you also have access to their preferred or proprietary codecs that aren't based on Quicktime or AVFoundation system APIs. Some are better than others. Older Quicktime (and FCP, etc) had lots of options, but those are dying or dead options now.
The BMD products do not capture 8MM, Hi-8 and VHS that well. FCPX will not even capture video using a BMD Intensity Shuttle. You have to capture video using BMD's Media Express software. The software is decent but the Intensity Shuttle needs a TBC more often than not to capture HI-8, 8MM and VHS. Having said that FCPX can playback video to broadcast compliant hardware using the Intensity Shuttle but it is kind of a pain in the butt compared to Premiere Pro.If you have a decent budget, I'd suggest getting an Aja or Blackmagic device/card, as those are high quality & known to work well with Macs. And...you get what you pay for, so GIGO.
Transferring Digital 8 using the Fire Wire port is the best option for the Digital 8 tapes but using the Digital 8 to pass through VHS will work just fine. The DV codec will work just fine no need to trans-code. -
I don't think you will like the BMD products for what you want to do because the AJA and BMD products probably will not work for VHS capture. The products main purpose is not video capture but instead real-time broadcast compliant playback for Avid, DR and Premiere Pro. Keep in mind streaming with the BMD products is different than capturing old worn-out VHS tapes that will probably require a TBC. Having said that I love using the BMD Intensity Shuttle but I use it for playback more than capture.
As far as research you can simply watch the video clips below to find out more about using the AJA and BMD products. If you want broadcast compliant playback then the AJA and BMD products are a must have and are well worth the price of admission. On the other hand if you are trying to capture VHS tapes using your Digital 8 camcorder to pass through old VHS tapes using iMovie that method should work just fine. You can leave them in the DV format. No need to trans-code.
https://youtu.be/PTQYJKQpazk
https://youtu.be/barrJWuBzCA -
I detest excuses for why crappy work is tolerable. Once you see the differences, it becomes less palatable.
ProRes422 is semi-lossy, more towards lossless than not.
DV is extremely lossy, throws away 50%+ of the color data, adds blocks, etc.
If you want lossy, then go for MPEG. It doesn't have the color loss aspect, just the blocking aspect.
Or ProRes422.
But do NOT use Blackmagic products, those work very poorly with SD video (VHS, etc), and will give you problems.
Elgato is really crappy as well.
Mac is really the wrong tool for capturing video. Editing from a camera, sure. But not capturing analog footage. Look into building/borrowing/whatever a Windows XP/7 system, anything from the past 10 years is fine, and get a quality USB capture option. Then you'll be in business, with quality, without problems.
Note that you also need a quality VCR, and some sort of TBC (at very minimum, an ES10/15 can give some TBC'ish functionality).
It's not as easy as buying any card, using any software, any computer, any VCR. Otherwise you'll find yourself in video hell.Want my help? Ask here! (not via PM!)
What is a quality USB capture option in your experience?
I do have an old PC in the basement with Windows XP that I built to be pretty powerful (wayyy back when) and it also has a firewire card in it too. I COULD see if that still runs, and then get a USB capture for the VHS stuff. I just don't know if or how that computer is running after sitting for so long collecting dust.
I also have an unused Dell laptop from my job that is no longer being used, has Windows 7 on it but I am sure the specs are not good for video work. Capturing maybe... but without checking, I would guess the machine is not that powerful. -
Medeamajic, after lurking in this forum for a while, I would be surprised if this comment doesn't start a whole debate over DV and all its horror.
VHS (and VHS-C, and 8mm etc) is what I am trying to do so thank you for saving me the trouble of extensive research on AJA and Blackmagic only to find out they're not really what I need. Once I get to my Digital8 tapes, then it's easy... until then I'm searching for the best "for me" analog solution.
DV is still on the table for me as an option, as horrible as it may be, and as much as it makes some people cringe.
ASSUMING I continue with DV... When you say leave it in DV, no need to trans-code, for what application do you mean? My plan was to convert all the tapes, save a copy of DV files (for my own archives, and for future editing if I ever want to compile clips into a project), convert all to mp4, save to a different portable hard drive for watching on TVs, and make copies of the mp4s for my siblings onto their own drives. -
Hi, Christina;
As someone who is in your (virtual) shoes, with my own ongoing/endless "project" of digitizing old photos, slides, 8mm/S8mm films, VHS, Beta, and 8mm/Hi8mm tapes (whew!) to share with family and friends, I've read all the posts here, with all the good and useful and interesting advice/commentary, and all I can say is ... good luck to you!
Okay seriously, it sounds like you're doing extremely well already with what you've got, you may not consider yourself experienced but hell, I'm impressed with what you've done so far, and your attitude and creativity going forward. Along those lines I'm coming at this from a possibly related perspective, where the first goal is, get something transferred and watchable for starters, to at least share with people who frankly would be satisfied watching old home movies on their phones for the most part. And as you go along, if you're having fun, then you go down the rabbit hole of avisynth scripting and lossless capture and all that fun (but slow) stuff that'll keep you entertained on those long winter nights. But until then, I think what you're doing so far is a very solid start.
1) Being you've already got a DV input/capture setup working for your DV tapes, assuming your DV camera has an analog/composite video input for your VHS tapes, just stay with that for now -- you'll have a consistent work-flow to get you going, you'll have stable video that you can then edit/encode into various other formats for sharing with family, and if it looks good enough for you, that's all that matters. It's not like you're throwing your tapes away afterwards, you can always re-do things later if you get a bee in your bonnet about "improving" quality, but whenever I start hearing from anybody starting to go on a bit about "best" quality, it gets me thinking of guys I know from car and motorcycle shows and swap-meets, we/they spend a hell of a lot of time debating the finer merits of flat tappet cams vs. roller cams, as roller cams have much more aggressive ramp rates that would cause a flat tappet lifter to dig into the ramp, whereas with your roller cam the ramp rate allows the valve to open faster and stay at a higher lift while ... see, it's a path to madness, and a good way to never get around to digitizing any of your old tapes.
2) You definitely want to keep DV archives of all your conversions, which you backup to at least three different locations (two local, one remote), keep your old tapes safely stored for if/when you decide to convert them later, and then convert the DV into mp4 (x264) via Handbrake (as you've already worked out) just for sharing purposes and for your average viewing. The reason why I say convert everything to mp4 is that it's a highly sharable format, with much support from pretty much any viewer, whilst DV is watchable but not terribly friendly to any and all playback hardware/software. That is, you can watch DV video straight out of the bottle, but it's kinda big and heavy -- it just takes more horsepower to play DV direct, much much easier and faster to view/share mp4.
Once you've transferred your stuff via DV, and made mp4 copies for everybody, then you share everything and one or more of your family members calls you up and goes, "Wow, I love that tape you have of Uncle Joe at the wedding, that was hilarious!" and you look at your DV file and go, "Yeah, that looks pretty good" or you go "Hmm, he looks a little less red in the face than I'm used to seeing him, maybe I can tweak the saturation and hue in editing ... or maybe I should just redo the entire tape and see if I can get just a little more 'oomph' out of this picture..."
Anyway, that's what I'd do. Or tell myself I would do, I've still got boxes of old 8mm home movies I've been telling myself I'll convert last winter ... well, maybe next Christmas. And never forget, if you're not having fun, it ain't worth it.
Have fun out there! -
Ozymango - thank you for this reply! I loved reading it and appreciate your advice and your analogies. I am already a bit down the rabbit hole as you said - mainly because I experienced some sync issues in the beginning and started searching for a better way, to jump through less hoops and streamline my process without having to pull apart files only to put them back together in order to keep the audio in sync (which is so counter-intuitive!). I've learned A LOT, read a lot, tested a lot, and I've lost a lot of sleep in the past 6 weeks or so since I started doing this again. I say again because I started this project over 10 years ago, when I had a PC. I was using the same equipment (VCR, Sony Camcorder, etc) and was capturing DV/AVI via Sony Vegas back then, with a firewire card I installed in the PC. I now am in Mac-World and experiencing issues I never had before, mainly with audio sync. (The DV file plays in sync, but once I converted to mp4, it was losing sync as the video progressed.) Quality, to me, looks pretty good! Although I guess I don't know what I am missing by using a "better" way to do analog.
I'd like to hopefully only do this once, although if someday I come across a better way, and the tapes aren't all disintegrated before then, I could do some of the more important ones over. But like you said, for now I just want to get them all done NOW while the tapes are still in decent condition. We're talking about tapes over 38 years old. Luckily we stored them well and they still play so far, but I don't know how much life they have left in them.
Would I be doing myself a disservice if I used something like this:
https://www.bhphotovideo.com/c/product/905778-REG/startech_svid2usb23_s_video_composit...BI%3A514&smp=Y
... which captures directly to mp4 (I think - I'm not sure if I can use other software to capture to a less-lossy format)? Plenty of people seem more than satisfied with the results they're getting but I don't know what type of eye they have or quality they're expecting compared to us crazies who spend hours combing through forums and talking to strangers about flat tappet cams vs. roller cams!
Or just stick with DV per your recommendation? I'm trying to wrap my head around how a USB capture device can do a better job than DV/Firewire because, without going into the limitations of DV (chroma, lossy, etc) I didn't think the data transfer rates of USB could keep up with a good quality transfer rate.
I'd really like to just find a solution that doesn't cause Audio Sync because the way I have to convert to mp4 is a pain. This is what I figured out and I don't know why it works. With my DV captures:
Converting with Handbrake, ffmpeg, etc. creates audio sync drift. If I use Quicktime to open the DV file, save audio stream only to m4a, convert DV video stream only in Handbrake (just delete the stream in audio tab), then use ffmpeg to put audio and video back together, somehow, that doesn't cause the sync issue. Go figure. But what a pain (kinda).
Somehow my ProRes422 Quicktime capture I did on my underpowered mac laptop, which I thought was going to melt when I converted it using Handbrake, came out perfectly. I don't know what it was about it that fixed the issue as there were too many variables and I only did one 8mm tape that way. But I used a different computer, on a different OS, using Quicktime to capture (instead of Vidi or iMovie), and an 8mm tape I hadn't converted yet any other way.
Anyway, let me get out of the rabbit hole. Thanks again for your (and everyone else's) feedback on the topic. With all the info in this forum, it's easy to get lost, and I appreciate the knowledge from everyone as it relates to my specific scenario. -
[QUOTE=ozymango;2547045][QUOTE=
2) You definitely want to keep DV archives of all your conversions, which you backup to at least three different locations (two local, one remote).
Anyone that has read my posts knows I agree. Some use a DV cam and loop through process and other use DV converters. They just work! No drivers needed. -
Christina,
I know you have some concerns but I think you will be OK using your method. I can edit DV using Premiere Pro and export to MPEG4 with no audio sync problems.
Instead of trans-coding maybe a good NLE would be better.(The DV file plays in sync, but once I converted to mp4, it was losing sync as the video progressed.)
It probably does look good. It is up the doubters to demonstrate a better method. The debate could end with a simple demonstration. Without one I will continue to use my method which is the same as yours.
Forget the naysayers. If you are happy that is what matters most!DV is still on the table for me as an option, as horrible as it may be, and as much as it makes some people cringe.
USB devices are hit or miss DV devices work.
I used a cheap USB capture device that some people have used but I wouldn't.... which captures directly to mp4 (I think - I'm not sure if I can use other software to capture to a less-lossy format)? Plenty of people seem more than satisfied with the results they're getting but I don't know what type of eye they have or quality they're expecting compared to us crazies who spend hours combing through forums and talking to strangers about flat tappet cams vs. roller cams!
https://youtu.be/kszzHAj8I_U
Both I and Ozymango have stated DV will work just fine for your needs.Or just stick with DV per your recommendation? I'm trying to wrap my head around how a USB capture device can do a better job than DV/Firewire because, without going into the limitations of DV (chroma, lossy, etc) I didn't think the data transfer rates of USB could keep up with a good quality transfer rate.
DV devices are broadcast compliant USB devices and software may not be. Premiere Pro can take a DV sequences and stay in-sync when exporting to MPEG4.I'd really like to just find a solution that doesn't cause Audio Sync because the way I have to convert to mp4 is a pain. This is what I figured out and I don't know why it works. With my DV captures:
Edit the DV in a good NLE and export to MPEG 4. See if that works. -
You do know what my next question is going to be, right?
By “good” NLE do you mean REALLY good like either FCP or Premiere? Or is there something you would recommend I try first (for Mac) before committing to one of the 2 biggies? It needs to be able to capture analog signal - this is the current problem with using iMovie as a capture program. It doesn’t recognize the input unless there’s a time code so I wouldn’t be able to use it til I get up to my digital 8 tapes, plus the export parameters are awful.
Any idea if Premiere Elements is worth a look? Assuming it does capturing and exporting... I am not doing any other editing at this time and so the other 2 options seem a bit overkill for my needs.
Edit: Sorry, it’s late and I just re read your previous post. Premiere Pro seems to be your pick. And you didn’t necessarily say to capture using it- just to convert. Still curious if there’s something less commital for my needs (instead of pay monthly for adobe)Last edited by Christina; 3rd Apr 2019 at 00:53.
My advice is to use a Windows machine. You'll have a lot more control that way.
As you predicted, the Holy War rages over DV versus lossless. My advice is still to try to establish a lossless workflow. You've taken such good care of these tapes for decades — you will convert them once and then you are stuck FOREVER with the digital results. Isn't it worth a little effort to get the best masters within reason? Along those lines, I would also advise you to use an s-video output. In most players, it provides a noticeably sharper image without color artifacts. And watch your audio levels as you convert; if they are too high, you'll get digital distortion. -
None of the VCRs I have access to have S-video output (I checked) and I can’t believe how much money people are getting for used SVHS VCRs. Plus you never know what it’s been through and I’m afraid of it eating my tapes. There is no other way, other than a VCR with S video output, right? Im stuck with RCA at the moment.
You have a very limited choice for USB capturing in the Mac domain unfortunately, Just use what you got. If you have PC I would recommend that USB device you linked in your post with AmaRecTV capture app, Capture in lossless compression and encode to mp4. Once you learn how to do it it becomes natural.
As for D8 and miniDV tapes, Firewire is the way to go. I don't know what app to use for Mac, I use WinDV on PC. -
Yeah, that's the problems with used equipment, Unless you have the repair skills it's hard to find a qualified technician and parts nowadays. Although I agree with JVRains, Capturing in S-Video is a big step to having a good source picture to begin with, VHS video chrominance (color) and luminance (black and white image) signals are recorded separately on the tape even if the tape in not recorded in S-VHS, it is better to keep them separate during capturing, When you use composite the VCR is combining those signals and reducing the picture quality notably the chroma or chrominance. Composite and DV is a bad combination, Each one has limited capacity in the color domain let alone used together. Also TBC and DNR if equipped help stabilizing and cleaning up the video before it gets digitized. it reduces a lot of unnecessary compression artifacts.
I was under the impression you were connecting your VCR to the Digital-8 to get the VHS tapes into the computer. A lot of DV cams can work like a DV converter box.
https://youtu.be/-vnL4nCv2RM
You can capture using Premiere Pro, iMovie or FCPX. I know Premiere Pro will stay in sync on the PC side. I imagine it will on the Mac as well. Premiere Pro Elements should work but I cannot say for sure. I can try iMovie and FCPX out in a few days if you can wait. Until then these links might be help. Premiere Pro might let you playback the timeline through your DV cam and then onto a Broadcast Monitor. If you have a lot of tapes viewing them on a broadcast monitor helps out a lot.
https://youtu.be/cwGU9VGlWhM
https://youtu.be/vATw63nn3OQ
Most VHS players don't have S-video. The Hi-8 and Super VHS players will.None of the VCRs I have access to have S-video output (I checked) and I can’t believe how much money people are getting for used SVHS VCRs. Plus you never know what it’s been through and I’m afraid of it eating my tapes. There is no other way, other than a VCR with S video output, right? Im stuck with RCA at the moment.
Capturing VHS tapes
By mtamimi in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2018, 01:09 -
IS the prores much better then AVCHD? A debunking video test about prores.
By Stears555 in forum Video ConversionReplies: 8Last Post: 21st Mar 2017, 02:22 -
Is prores or h264 more efficient compression at prores bitrates
By ezcapper in forum Newbie / General discussionsReplies: 14Last Post: 6th Feb 2017, 20:03 -
Capturing Hi8 tapes - latest advice.
By ex_directory in forum Capturing and VCRReplies: 21Last Post: 20th Sep 2014, 02:51 -
What's the best device for capturing VHS tapes?
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2014, 19:38
