i am trying to get the best pic out of my vcd..... under adv settings and image filters, is there any filter that i can cut on to make the pic better????
especially under video filter because i notice latley wit panasonic that my movies audio is going outta sync and i am tryin to find out y especially since it dont happen with tmpgenc (yet anyway)
For PAL, you should change the GOP sequence to 12-12-3 (the third one down the the drop-list). For NTSC, leave it as the top option (the default).
Colour tone correction: PC ONLY!!!
Image filter: if you are encoding from a DVD rip, "none" and "none" are the best settings.
These settings don't affect A/V sync though...
Regards.Michael Tam
w: Morsels of Evidence -
ok.... well most of mine movies are avi that i dl so should i use any image filters for that??????
It depends on the source...
I personally find that anything more than:
Noise reduction: weak
Video filter: adaptive, weakest
leads to overly soft video. In such a case, it may be better to apply filters on your video before encoding (e.g., VirtualDub) or use another encoder with more advanced filters (e.g., TMPGEnc).
Regards.Michael Tam
MPEG1 custom GOP settings
By sipposa in forum Video ConversionReplies: 8Last Post: 11th Jul 2011, 19:23 -
kmttg +encoder settings
By Danneauxsvh in forum Video ConversionReplies: 2Last Post: 4th Jan 2011, 15:38 -
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 10:16 -
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2010, 23:32 -
hc encoder profile settings
By bmwracer in forum Video ConversionReplies: 12Last Post: 28th Feb 2008, 16:46
