I'm using a video program with a Rii Keyboard. Bought it specifically for the size. It might be causing a problem though.
I'm doing my editing, and then I go to render, I come back minutes later to find that the computer has rebooted. It doesn't happen all the time, just randomly.
The keyboard has a feature where it shuts itself off when it is not used for a few minutes. I'm wondering if that is interfering with the computer at all?
The obvious thing would be to temporarily use a regular keyboard, change nothing else, and see if the problem goes away.
What is the point of a keyboard shutting itself off ? (If I read - and often do not - correctly)
I do have several bluetooth keyboards that regularly shut down, but quickly awaken with a key press. No problems.
And I do have a Rii Mini Wireless 2.4GHz Keyboard that also works with no problems. It has a built-in rechargeable polymer Lithium-ion battery.
I would definitely try a different KB to test for KB issues. Maybe a stuck key problem.
And if you are using Windows, I would check the system 'Event Viewer' for errors that may tell you about shutdowns.
It's in 'Control panel>Administrative Tools>Event Viewer'
Spanish layout keyboard
By CM120884 in forum ComputerReplies: 5Last Post: 6th Jul 2018, 03:06 -
Can you install windows without a ps/2 mouse or keyboard
By adamf154 in forum ComputerReplies: 16Last Post: 25th Jan 2018, 04:25 -
laptop keyboard light
By vhelp in forum ComputerReplies: 3Last Post: 3rd Dec 2016, 14:20 -
how do i change the keyboard to standard .. [solved]
By vhelp in forum ComputerReplies: 2Last Post: 3rd Mar 2016, 18:54 -
Needed: keyboard shortcuts for PotPlayer
By Harry B in forum Software PlayingReplies: 3Last Post: 8th Sep 2014, 15:31
