    Mar 2019
    Danmark
    A friend of mine gave me a flash drive with the UHD of Jurassic - Fallen kingdom to test out the new 4K Sony TV I bought to see if I should keep it or return it. But what do I do with a folder full of files like "6H3iQjYlwDw3jKERqIMP6o", "94IzkzNzD1D4gGF_4TDidk02SX7DZ" and all the way to the short "iDBu1s"??? None of the files have any extension. They show nothing but the size when run through the software "MediaInfo" and I can't mount the folder in PowerISO. What do I do?? My return window for the TV is next saturday. Thanks.
  2. No doubt the files are encrypted anyway. Do you think Hollywood would allow you to copy their crown jewels so easily?
  3. You may find lots of UHD demos on youtube.
  4. Member DB83's Avatar
    Jul 2007
    Or ask your 'friend' to give you a proper rip.
    Since you do not own the disk you can hardly hope for assistance. And technically it then becomes warez and forum rules then prevail.
