Is there any way to convert a Pal VCD cue/bin file to a Ntsc cue/bin file.
Thanx
The only way that I have been able to convert PAL VCD to NTSC VCD was to extract the MPEG from the bin with VCDGear. Then run the MPEG through TMPGEnc to convert to 29.97 fps. That took about 1 1/2 hours on my dual 733Mhz PIII box, per 400(ish)MB title. The results were much better than watching the PAL version in my Apex 500WM player. This will become my standard procedure for dealing with PAL VCD's. Hope this helps.
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 13:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 09:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 15:48 -
Argh! More converting PAL to NTSC!
By Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2007, 19:56
