Hello,
I am trying to correct an out-of-sync movie by applying a delay in milliseconds to the audio track in mkvtoolnix. So far I have used VLC's track synchronisation to manually determine the delay. However this method is not very precise as shifting the delay by 50-150ms does not make any difference -at least in my eyes.
Is there a way to precisely and automatically determine the delay and then give it to mkvmerge when mixing?
Many thanks,
vangeliis
Precisely? Like to the millisecond? No. Automatically? Not a chance. However, VLC isn't accurate enough. In MPC-HC you can adjust in 10ms increments. But if 50ms and 150ms don't sound any different to you then there's no way you'll be able to tell just by listening. When I want more accuracy I use AviSynth's AudioGraph filter to impose a waveform over a video to tell when a sharp noise, like a gunshot or something similar, takes place. It can come to probably 20ms or so of being accurate, given that the video frames are roughly 40ms apart. And it's usually said most people can't tell the difference up to about 100ms.
Lip reading is no good at all. As I said, a gunshot. A door slamming. Any kind of loud sharp noise.
I know nothing about Macs. Sorry. -
Thread moved to the mac forum where you can get more help.
Dialogue can be synced with practice, but a sharp, loud sound with visual cue is best. That's why they still use these for backup.
For a free video editor with waveforms, check out https://www.openshot.org/.
Software that can precisely adjust audio length without changing pitch?
By bizzybody in forum AudioReplies: 5Last Post: 7th Oct 2017, 18:45 -
How to determine the delay between sound and video ?
By Kand in forum Newbie / General discussionsReplies: 7Last Post: 17th Jul 2017, 00:32 -
Muxing MP4 (Audio+Video) to M4A (Audio)
By meganoob in forum AudioReplies: 4Last Post: 4th Oct 2015, 22:34 -
Muxing video and audio into mp4
By gracemichelle in forum EditingReplies: 3Last Post: 13th Mar 2015, 20:31 -
Mkvmerge - no video after muxing several audio tracks and bd remux video
By portgas in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2014, 08:24
